bending fuel oil line
How do you bend coated fuel line? so far I gotten away with bending around a piece of pipe or a can etc. So I figured I would up my game and picked up a Kline roll bender "Klein-Tools-51006-3-in-1-Tubing-Bender"
The plastic gets beat up a bit and it just one radius.
thanks, but where do I find a tubing bender that is 3/8 plush that jacket?
"the groove needs to match the od of the tubing and coating." yes, but who makes this?
a little bit bigger is probably ok. a little small is going to tear up the plastic which its probably just a cosmetic issue.
I can't see using a bender on contained oil line ? A boot works in the corners ..
For bright work I like ratchet type , looks like a cross bow . You would need try the larger size
I have that set @HVACNUT but the bending forms are all black plastic like the clamp die. I like your pretty colors!
Can't get hands dirty.
i watched a video of someone using foam in a can without gloves the other day. there are lots of things that i don't wear gloves for and lot of other things i sometimes wear gloves for because it is easier than scrubbing my hands in gojo or paint thinner but latex or nitryl gloves are great for foam in a can because more or less nothing takes that stuff off.
I like Rectorseal "True Blue" pipe dope. It works good to prevent leaks. Not so good it's tough to get it off your hands and gets on the tools as well.
Only Time removes that stuff! 😄
