Radiator expansion noise after valve replacement
I copied the title from a post from years ago because I'm having the exact same issue!
Long story short, we had leaks in several of the intake valves, so we had them replaced. The guy did a great job, but after the replacement, one of the pipes by the valve now makes really loud and annoying expansion sounds. Previously, it had never made any noise at all, and unfortunatley it's in our bedroom, so it is keeping us up at night. It's definitely not steam hitting water (we have that in some other rads, and it's intermittent and not nearly as annoying). This is like a tic-tic-tic sound that is less loud than banging but far more annoying.
Anyway, the other thread said to try putting a piece of plastic between the pipe and the wood because the pipe might have moved closer to the wood during the valve replacement, and the sound is the metal hitting that. I'm wondering if it would be OK to use a piece of cardboard instead, or if that is dangerous because of the heat of the pipe.
Cast iron radiator or fin tube!
All cast iron
There is no risk from temperature. I have a radiator that ticks. I have not been able to solve it. Luckily my wife likes it because then she knows the heat is coming.
Cdardboard won't be hurt — but it won't help much, either. It's the slippery plastic which does the trick. Any possibility of moving the radiator just a bit so that the pipe clears the wood?
Cardboard is fine. Why not just increase the hole through the floor and put an escutcheon on to hide it? Multi-tool works great for that.
I pushed it back some and it has stopped for now
a milk bottle plastic pieces under the feet.
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
