Pipe Vise Stand and Bracket
Alan (California Radiant) Forbes Member Posts: 4,676
edited January 22 in THE MAIN WALL
Just bought a new truck. It comes with everything except a slide-out pipe vise bracket like the one pictured, but I can’t find one for sale anywhere. Fabrication is a second choice if I can’t find one off the shelf.
Does anyone have a source?
    pecmsg Member Posts: 6,995
    i’ve seen that slipping for the trailer hitch a little low but out of the way
  • JUGHNE
    JUGHNE Member Posts: 11,539
    American Van has a floor mount telescoping bracket for vice mounting.
    I have gotten a lot of items from them and all was good.
  • JimP
    JimP Member Posts: 99
    This image is from the Knapheide website.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,058
    edited January 21
    Hi, Like @JUGHNE , I used their van vice mount with great success. https://www.americanvan.com/slide-out-vise-mount-av-svm-11-1006.html
    Yours, Larry
    hot_rod Member Posts: 27,232
    That bumper is stout enough to mount the bottom 1/2 of a regular yoke type pipe vice.
    Or detachable receiver type, like this.
    Nice truck, beefy pipe rack. I like the colors
    edited January 22
    A lot of guys and gals swear by this Bigfoot type of vise. You could rig a bumper mount, and use it as a portable with some clever bracketing
    mattmia2 Member Posts: 16,322
    i bought one of those guillotine style pipe vises used with the intent of bolting to a couple foot long piece of 2x.
    ethicalpaul Member Posts: 8,598
    I like the way you worded that. I have a lot of intentions too 😅
    Nice truck btw!
  • HydronicMike
    HydronicMike Member Posts: 315
    Looks like you have this one, and they made their own mount
    if you do a lot of threaded pipe these portable threaders are super handy. They have cordless versions now.
    I rarely used the pipe vise after I got one of these.
    Does that truck have 120V receptacles in the bed.
    EBEBRATT-Ed Member Posts: 20,028
    I have an Amigo 2 that I bought used 31 years ago. Works great i think.
    I wouldn't know my brother scoffed it off me over 20 years ago and I haven't seen it since. Only threader I have left sold the others. Much lighter than a Rigid 700 and plenty of power.
    mattmia2ethicalpaul
  • Intplm.
    Intplm. Member Posts: 2,979
    @Alan (California Radiant) Forbes Nice new ride. I can see why you want what you have had before, that good old familiarity often works best.
    I use the big foot. The problem I have with it is you can't crank down on something, it will not stay stationary. Otherwise its a good portable vice.
    I looked in the Ridgid catalog and could not find anything there. Try giving them a call. 1-800-474-3443. They might have something not listed, or a recommendation. If not, the company that sold you the utility box on your new truck might have something.
    I sent you a message in your mail for some other thoughts.
    Just for my education, do those portable threading machines still require a vise, or do they have an integrated vise that prevents a free pipe from spinning?
  • Intplm.
    They require a vice. They usually come with a clamp that is clamped onto the pipe. The clamp has a post or integral rod. The threader is inserted on that rod so the threader can travel the length of the cut of the thread.
    The clamp is pictured here, the part farthest to the right.
    ethicalpaulmattmia2
    @ethicalpaul
    Yes as @Intplm. mentioned Reed, Rigid, Rothenberger, Rems (why do they all begin with an R) and Milwaukee all have a vise to clamp the pipe some designed a little different than others.
    You can usually thread 1/2 or 3/4 without the vise but is needed on larger pipe
    there is a harbor freight version too
    As long as you have enough space to get the machine positioned, you can thread pipe in place. Which can be very handy for cutting in fittings or replacing sections of pipe.
    I've seen that, it looks amazing when you can do it
    I had a 3" welded gas line that we had to make some changes to. It was all low pressure gas. It was in the ceiling in an office building so welding was not really an option. No Mega Press back then.
    Luckily there was space around the pipe we cut it with a band saw and mounted a Ridgid #141 threader with a ridgid 700 on it and cut a thread on it.
    Not fun up in the air on a ladder but it worked.
    ethicalpaulIntplm.IronmanAlan (California Radiant) Forbes
    A chain vise is handy if you want to hold "other" larger diameter or odd shaped stuff. I used one for cutting the smaller fire wood with my truck vise.
    Chain vises are the best. Cut a whole bundle of threaded rod, square tubing, angle, channel, Unistrut…..oh yeah and pipe and tubing too.
  • Guys: I got a new chain vise from Santa and all I need is the stand. I don't thread pipe anymore, so it's just tightening and loosening fittings from pipe, cutting PVC and galvanized flue pipe. And it looks cool, hanging off the back of my truck like I know what I'm doing.
    It will look better when it is covered in pipe dope, a few pipe chips and dirt
    Intplm.
  • Lance
    Lance Member Posts: 334
    I had a Ridgid bolt on chain vise. I mounted it on some steel c channel that I fashioned into an upside down L stand. I secured a c channel bracket to my bumper so I could drop the vise into it. This kept my vise in the truck, and allowed me flexibility in using it and transferring it to another truck. I go through trucks quicker than I go through through tools. It was my answer to a truck without a hitch. Smaller than a tripod vise, lighter too. till in use 40 years later. I like tools that are forever. ⚒️
  • ChrisJ
    ChrisJ Member Posts: 17,256
    You literally saw a picture of a setup I was using with a Ridgid 700 back in October…..
    I guess you're forgetting stuff in your old age. 😁
