Cracked bonnet nut
I have a large valve that has a cracked bonnet nut. The system is losing water from it. Lucky it’s in the basement so the only damage is the loss of water but I want to fix it. Can I buy a replacement nut? I can’t figure out where. Replacing the valve is out of the question-just too much pipe that would need to be done too.
Picture?
A local machine shop may be able to fabricate one for you. Also you can cut one pipe and replace the section of pipe with threaded pipe nipples and a union or a flange after all the threaded connections/surfaces are sealed
I assume the bonnet nuts are unobtanium? Could I remove the valve guts and cap it?
You could cap it, but they aren't NPT American Pipe Thread. Mad Dog
id try the hose clamp and see if it will seal up until the off season when you can replace the valve. maybe add a little more packing and don't crank too hard but the only way to get that nut, especially since i think that valve it 50+ years old would be to salvage one from another valve or have a machinist make one.
interesting topic, got a question: What would cause the metal valve nut to fracture in the first place? Was it user error or abuse or just a natural occurrence. Finding that out may prevent re-occurrence
Regards
RTW
I don't know why this one cracked. I don't think it was me, but it's possible that it was.
What type of thread are they?
If it was mine and couldn't figure out what thread that is, I'd pull the valve apart and tap the inside to whatever it'll work with and plug it.
Just another idea..
Matt's hose clamp idea could work too.
Remove the insulation and try and identify the manufacturer of the valve. Might be able to find the manufacturer who could send you a replacement, if available. i mean if its that much work to replace.
Try to get that part from this business in MA that restores Cast Iron radiators, just may have that part lying around in the shop
Contact — making people warm... (HOME)
Regards,
RTW
- 15.8K Strictly Steam
