Cracked bonnet nut
I have a large valve that has a cracked bonnet nut. The system is losing water from it. Lucky it’s in the basement so the only damage is the loss of water but I want to fix it. Can I buy a replacement nut? I can’t figure out where. Replacing the valve is out of the question-just too much pipe that would need to be done too.
    EdTheHeaterMan Posts: 12,948
    edited January 12
    Picture?
    A local machine shop may be able to fabricate one for you.   Also you can cut one pipe and replace the section of pipe with threaded pipe nipples and a union or a flange after all the threaded connections/surfaces are sealed
  • Dsisson
    Dsisson Posts: 118
    I assume the bonnet nuts are unobtanium? Could I remove the valve guts and cap it?
  • Mad Dog_2
    Mad Dog_2 Posts: 8,755
    You could cap it, but they aren't NPT American Pipe Thread. Mad Dog
    id try the hose clamp and see if it will seal up until the off season when you can replace the valve. maybe add a little more packing and don't crank too hard but the only way to get that nut, especially since i think that valve it 50+ years old would be to salvage one from another valve or have a machinist make one.
    Intplm.
  • RTW
    RTW Posts: 285
    interesting topic, got a question: What would cause the metal valve nut to fracture in the first place? Was it user error or abuse or just a natural occurrence. Finding that out may prevent re-occurrence
    Regards
    RTW
    usually overtightening, they split somewhat easily if you just crank on them instead of fixing why they aren't sealing.
    RTWLarry Weingarten
  • Dsisson
    Dsisson Posts: 118
    I don't know why this one cracked. I don't think it was me, but it's possible that it was.
    What type of thread are they?
  • ChrisJ
    ChrisJ Posts: 17,763
    If it was mine and couldn't figure out what thread that is, I'd pull the valve apart and tap the inside to whatever it'll work with and plug it.
    Just another idea..
    Matt's hose clamp idea could work too.
  • pedmec
    pedmec Posts: 1,488
    Remove the insulation and try and identify the manufacturer of the valve. Might be able to find the manufacturer who could send you a replacement, if available. i mean if its that much work to replace.
  • RTW
    RTW Posts: 285
    Try to get that part from this business in MA that restores Cast Iron radiators, just may have that part lying around in the shop
    Contact — making people warm... (HOME)
    Regards,
    RTW
  • RTW
    RTW Posts: 285
    To original poster:
    I hope you post a follow up on your final solution, it could benefit others that currently have that same bonnet nut issue; I doubt you're the only one
    Regards,
    RTW
    you could try going to a good hardware store, the kind with the faucet stems and seats and other parts and see if it matches up with a packing nut for a faucet. If you can find the same id and thread you can fix the hole size with a drill or washer depending on which way you need to go. A set of pitch gauges would help here but you could also measure a couple threads on the outside of the valve with a caliper or micrometer and divide and invert.
  • MikeL_2
    MikeL_2 Posts: 561
    I suggest removing the nut, clean all the surfaces, clamp it & carefully solder it. Ad a ss clamp after reassembly before tightening it against new packing…
  • 4GenPlumber
    4GenPlumber Posts: 176
    Remove the packing material. Clean the entire area. Solder the packing nut to the bonnet and the stem. Remove the handle bc it will never work again.
    cm6230
  • Long Beach Ed
    Long Beach Ed Posts: 1,851
    edited January 29
    We pull it up, cut a strip of rubber and wrap it around the nut with a stainless hose clamp. Or press an automotive-type clamp on with a Pex-ring tool. Repack the valve and gently reapply the nut. It shouldn't have to be tight at all if the packing is good.
    Of course a machine shop can make one also. Just need a guy who has the time to do the work.
  • AdmiralYoda
    AdmiralYoda Posts: 816
    edited January 29
    I like the hose clamp idea….but if that doesn't work maybe try a C-Clamp at the top and bottom of the nut to close the gap in the crack? You can get a small one for $2-3 at your local hardware store.
    hot_rod Posts: 28,706
    Brass can fatigue over time. It depends on age, the alloy, the amount of stress on the nut, or dezinification where the zinc in the alloy degrades from certain water conditions.
    Probably a combination of these events.
    A good welder could braze over the crack if you remove and clean it up.
    It would be fairly easy to machine a nut from bar stock once you determine diameter and pitch of the thread. That would be the best permanent fix.
    The hose clamp is a simple first step.
    Long Beach Ed
  • RTW
    RTW Posts: 285
    Seems original poster fell off the radar after possible posted solutions. Maybe not an immediate concern to fix
    Regards,
    RTW
