Burner Motor replacement capacitor.
I have a few Carlin motors with bad capacitors. These are the older PSC motors with the round capacitor PN#98022CAP which appears to be discontinued. Does anyone know of a source for a substitute?
good idea, thank you!
motor shop, supply house…
Look at getting a brand spankin' new one off of amazon.com
that's the closest match I have found yet (you found). Figures its at walmart 🙄
What I have found so far, that fit the numbers are "run" capacitors.
That is specified as a "run" Cap. however, Carlin says "The Carlin PSC Motor utilizes a capacitor to assist startup and run of the motor."
Give me a break Carlin
That way Carlin is the only company that you can get that from. You can get Run Capacitors anywhere they sell capacitors, but you can only get the original Carlin part from someone that may have some old stock laying around somewhere.
By the way…. I have this device for sale
You can only get a smoke keeper from me!!!
…you can always just purchase a bunch of 3 amp fuses anywhere they sell auto part, But if you want the genuine original "Smoke Keeper®", that is guaranteed to keep the factory installed smoke inside the 24 volt transformers, then you must buy the Smoke Keeper.
This is way better.
How to use it.
Now we are getting off topic…. although I like the Lil Popper over blowing fuses to find a problem. The point was that Carlin called their run cap a start and run assist cap in order to make some people that don't know any better, believe that their more expensive repair part was different
and also annoying the "Residential Oil Training guide" I received during training two months ago says the Caps are field replicable. I cant even find Caps for the new motors. Honestly a third of the people we service can hardly afford oil, much replacing a motor when they really only need a capacitor.
