Steam pipe epoxy
trivetman
trivetman Member Posts: 262
edited January 13 in Strictly Steam
whats the best epoxy to fix a leak in the steam main to get me through the winter? I would much rather deal with repairs in the summertime when heats not needed.
idk what it looks like yet other than the insulation (fiberglass) is pretty wet.
    mattmia2 Member Posts: 16,357
    a hose clamp and a little piece of rubber or heater hose works well on a pinhole.
    kcopptrivetmanBobC
    Jamie Hall Member Posts: 27,190
    trivetman
  • kcopp
    kcopp Member Posts: 4,663
    You have access to Mega Press?
  • ratio
    ratio Member Posts: 4,216
    I used this to seal a leak in a 4" steam main, lasted for over a year before I got around to making the repair: https://cleanfit.com/blue-monster-compression-seal-tape.shtml . The Lowe's around here carries a package of 12" strips, which wouldn't help me but if you're working with ½ or ¾ it should be fine.
    I've also had some luck forcing a piece of plumbing epoxy into a hole in an abandoned section of main that blew out a small hunk due to water hammer. Dunno how long it's going to last, but the real fix will be to remove the section & relocate the flange. I sure wish it wasn't 8" threaded pipe.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,582
    edited January 13
    I have seen rubber Fernco fittings on steam mains. Some of them had been in place for years. Would obviously not suggest such a thing.
  • BobC
    BobC Member Posts: 5,554
    If you go with any kind of a clamp don't go crazy when tightening it. old rusted pipe is not very strong.
    Bob
    3PSI gauge
    STEAM DOCTOR
  • dabrakeman
    dabrakeman Member Posts: 979
    I also had success with a kind of tape, an epoxy soaked mesh tape in my case. The home made clamp concept should work too. Don't think you should have to pay for a $60 device…
  • trivetman
    edited January 14
    well…maybe not as bad as I thought. Definitely want to replace the pipe in the summer, but nothing is visibly leaking with the insulation off and boiler running.. i think the fiberglass was acting as a wick drawing the water through the weak spots
  • Intplm.
    Intplm. Member Posts: 2,981
    Maybe some JB Weld first, than any one of the above mentioned clamps.
