Using epoxy on a crack on the crown of a cast iron steam boiler
Joseph_4
Member Posts: 320
There's epoxy and there's epoxy. Better luck with expensive stuff.
can you post a wide shot? i have used epoxy and metal plates to replace holes in my boiler. if this is outside of burner cavity, then you can use JB Weld Water. don't bother with very expensive stuff (i've tried both).
Steam Heat YouTube videos:
https://www.youtube.com/@HeatingBlog0
- 15.8K Strictly Steam
