Steam boiler
Gomichigan7383
Gomichigan7383 Member Posts: 3
steam boiler keeps running 10-12 minutes then shuts off for a minute or 2 then comes on. Pressuretrol and pigtail are new. All radiators are hot. Its going off on pressure what do you think is the problem i appreciate your feedback
    Jamie Hall Member Posts: 26,884
    Boiler is slightly oversized and cycling on pressure, unless the LWCO is a Cyclegard, in which case it may be the Cyclegard which also cuts out with about that timing to get a really good read on water leve.
    Sounds normal, either way.
    bburd
    EBEBRATT-Ed Member Posts: 19,721
    edited January 2
    Oil or gas boiler? What pressure is it tripping off at? Is your venting adequate?
  • Gomichigan7383
    Gas boiler; it has a safeguard LWCO that goes off every 20mins for a self check but in-between that the pressuretrol goes off at 5psi then a minute later boiler comes back on
    Has it always operated like this? What has changed?
    109A_5 Member Posts: 3,538
    5psi seems excessive, what is the pressuretrol set at ? Are any radiators closed off ?
    5 psig is WAY too high. Picture, please, of the pressure control device. Also, has the pigtail to it been cleaned?
    Kind of wonder if the gauge is accurate. Since "Pressuretrol and pigtail are new". Is the tapping into the boiler blocked ?
  • Gomichigan7383
    Pressuretrol is set at 2;2 pigtail and Pressuretrol are both new gauge is tapped into the top of the boiler all radiators are open and hot
    If the pressuretrol is set to cut out at 2 but the pressure still goes up to 5, something is quite wrong. The pressuretrol might be out of calibration — most of them are — but that far out would be odd. One has to wonder… is it properly wired in?
    If you have a PA404 Pressuretrol it should be set like this picture, however you may have other issues if the pressure is actually going up to 5psig.
    Gomichigan7383
