Help with recommendation of Gorton steam cast iron radiator vents sizes?
n1976jmk
n1976jmk Posts: 22
edited December 2025 in Strictly Steam
Hi, I am the owner of a 100 year old home with a single pipe steam boiler system (a DIY homeowner) and live in northern NJ near Newark Airport. I have owned the home for 10 years now, with a natural gas powered Weil McClain boiler is 16 years and well maintained with cast iron single pipe radiators. This year during the annual PM before the heating season it was discovered the natural gas water column only showed 3.8 (without any other natural gas pulling in the house). So we had the Natural gas company come out, they changed the regulator and meter, now its 6.5 water column and with everything natural gas powered on in the house on high, its 5.8. So that is resolved. **There is 3rd floor in the house but no radiators up there, on the 3rd floor we have a mini split that does heat in the winter.
The steam pipes are all insulated in the basement but the walls of the house are not insulated except a couple of the rooms. Right now the heating runs pretty well in the house, I am overall happy. But I want to dial it in a little more, I have all the radiators pitched properly, and all very clean, but I want to focus now on changing the air vents on all them. Right now they are a mix of Gorton, Hoffman 1A adjustable and 1 maid-o-mist. I want to change them all to the Gorton, either 4, 5, 6, C, or D.
Also there is one large Gorton main steam valve in the basement, I have had two HVAC techs here this season, they said everything is looking and running good.
But the Hoffman's make some noise, after reading and researching this for the most part is 'normal' for a lot of folks. I am just looking to dial in the heat some more and get the heat as even as possible throughout the house.
I have a Ecobee premium thermostat with it configured and knowing I have a steam boiler, with it set with a 1 degree temp differential. I have it set to 69 degrees during the day (and I have 5 remote temp sensors (1 in each room) on 1st floor). At night, I have it set to 67, and I have 3 remote temp sensors (1 in each bedroom) on the 2nd floor).
I am attaching the floor plans for my house with the location and size of my radiators and where the boiler is in the basement in relative to the rooms/floors and a few other photos.
Please let me know if I can answer anything else or if I missed anything or was not clear in any of the explanations.
My goal of this post, is to get all of my radiators onto Gorton air vents, from what I read, I have a good idea already
of what # size Gorton vents I want to use on each radiator but I am looking for the experts here to help and see what you all suggest since you know better than me.
thanks in advance!!
Jonathan
IMG_0502.jpeg IMG_0501.jpeg IMG_0216.jpeg IMG_0427.jpeg IMG_0212.jpeg IMG_0131.jpeg IMG_0309.jpeg IMG_0215.jpeg IMG_0526.jpeg IMG_0503.png
reggi
