Heat-Timer Varivalve
I am new to steam boiler systems and my boiler is losing a good amount of water as I need to add every couple days. I have replaced a couple hissing air vents which I am hoping helps. In the house I have maid o mist and gorton. Then in the garage I came across this one ( see picture). I saw a couple drops of water come out so will attempt to replace but looks much different that my others. Can anybody tell me a bit about this one?
thanks for the responses. Do you think I should just replace with a maid o mist like what I have inside the house? Although I am not sure what size I would use. It is mostly 5 or 6’s inside (I have replaced with whatever the previous owner had in there).
a bigger leak is what concerns me. I am starting with air vent replacements and will need to get professional help in locating the leak if it doesn’t help.0 -
Do you have a buried wet return? Do you notice a lot of white "smoke" coming out of your chimney when the boiler is firing? These are two common areas of leaks.
I want to really like that
Vent-RiteVari-Valve vent because it's made just down the road from me in Fairfield, NJ, and I'm going to test one in my home very soon because I wonder if I may have been too harsh on them in the past. I do see a lot of them in people's homes around here and that's another reason I want to test it myself. The company itself brags that they have a very fast top rate rivaling the massive and expensive Gorton #2 main vent.I do like Maid O Mist and Gorton although it seems just about any vent can fail just about any time, while other units of the same model can go for years.
I have heard complaints about the Varivalves on this site. 2 years ago I tested all of the popular vents. Unfortunately, the complains about these valves were verified. Two of the 3 I placed in my system failed after two months. They would not open.
It's kind of depressing about vents, I have seen Maid o Mist and Gorton both fail, both radiator vents and #1 main vents. That's why I'm expanding to try one of these myself.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 50 Industry Classes
