Triangle Tube Ceasing Operations
They ceased operating this morning. Any hear of a buyer, or are parts going to be unobtanium?
WOW. I guess that happens when you have a recall that big. Customer service is being handled online so far at techsupport@triangletube .com
Ceased operations completely. Even the tech support line says they are out of business as of today! All reps are released from what I was told. I just sent an email.
I think that happened to eastern airline in the 70s. Maybe 80s
1991. aren't there like regulations about this type of product that it has to be supported and such?
You would think! I have alot of them installed and one in my own home!
I work for a large-ish distributor of their product and we have no information on what happens next. The rep was informed this morning that they are closing effective immediately. reps are on for 30 days as is usual with rep agreements, some reps have stock and do not know if they are stuck with it or not!. Seems they are now in charge of playing PR as triangle tube hasn't made a public statement about it. not surprised, lack of accountability is a sign of poor leadership so it makes sense they are closing up.
Going to try to call the Ideal boiler number and see if they are still in business, Triangle tube is part of the same company as Ideal so if you need parts that would be a source!
Edit: Ideal phone number still active, they have distribution in the east coast and west coast, with the Triangle Tube brand name in the middle. Hopefully they are just transitioning everyone to the main brand name, any Instinct boilers you have installed should be very similar if not identical to the Ideal boilers.
They had a gasket leak carbon monoxide into the cabin?
And if the doors are locked, who will "THEY" enforce that rule against? And who is THEY anyway?
I know that my customers with TT boilers won't get a dime out of me. I don't even live there anymore
called ideal...... they are closed too. Shocker
The Ideal number has the same message during business hours. I called again after hours and it makes no mention of being closed. I think someone forgot to change the after hours message.
man thats a bummer, I got a customer who has at least 5 boilers that are affected by the recall. They may be real sad tomorrow
Tom
Montpelier Vt0 -
If and when the parts run out, we'll be replacing boilers that could have gone on.
I'm sorry to see the company go like that. They've been with me my whole career.
Closing their doors may stop some of the hemorrhaging, but it won’t relieve them of the liability for what’s already out there in the field.
We had over 25 hours trying to correct one that we installed at the end of last season before they announced the recall. Everyday, tech support kept telling us to do something different when they knew there was a design flaw in the boiler. We finally demanded and got a new boiler. Then, a couple of weeks later they announced the recall. They knew all along that there were issues.
It’s a shame since they were the ones that introduced the fire tube HX in the US and the original boilers were very reliable.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.3 -
Ideal and TT/ ACV are part of Group Atlantic a French company. I don't recognize any of their other brands? In the US.
What makes no sense to me is the boilers they were having problems with were the old "good design" (prestige) I haven't had issues with the "ideal built" instinct boilers with the exception of a board issue that caused slightly out of spec combustion on LP units, and that was during the first year they were being sold.
Forum Moderator
Im also curious about the fire tube design. I dont think I have it right, but for some reason I was told that TT designed and patented the fire tube design. Then they lost the patent. That sounds ridiculous anybody know the real story?
Tom
Montpelier Vt0 -
Really sad, they were pioneers in the industry….
This is quite a surprise. I'm sad to see them go. Why couldn't it be Navien instead?
I really liked most of their boilers, the fire tube heat exchangers are easy enough to clean. Triangle Tubes controls were easy to use. I never had any problems with them.
The amount of stuff involved in correcting the recall was kinda ridiculous.
2 -
People involved with the original iteration of IBC designed the firetube heat exchanger. They weren't able to get manufacturing to scale up and so the manufacturer they had re-tool all their equipment to make the firetube sought out new customers so their investment wasn't wasted. Triangle Tube was the biggest customer that bought them and ran the design through the tests (this is the first iteration of TT) The manufcaturer of the heat exchanger had some weird family drama that resulted in a split, and one of the manufacturers underbid the other to steal business but wasn't able to weld the stainless steel correctly, that resulted in about 6 months of defective heat exchangers that just about put TT out of business. The firetube design was still solid and now cost less money due to lack of trust, that is when you saw every other boiler manufacturer jump on the wagon. Triangle tube never fully recovered from those 6 months of defective heat exchangers, my customers still talk about it. This is the abridged version there is a lot more to the story of the 2 heat exchanger manufacturers but it really isn't important in the long run and I would probably get details wrong, basically just drama and business mixed with family.
3 -
Tom, TT simply had an North America exclusive on the AIC firetube heat exchanger. TT did a couple stupid things and lost their exclusive. I heard this all from a higher up at AIC.
I think you mean AIC, not IBC, for the design of the FT HX. The failure in welds was done when TT tried to manufacture their own. AIC had nothing to do with the TT failures.
AIC manufactured it. Folks with IBC pre-intergas actually designed it and contracted AIC (though it may have been a different name at the time) to produce it. the manufacturer retolled machinery to make it and IBC sort of disappeared, the manufacturer decided to find a buyer since they had done all the retooling to make it. TT never manufactured their own, there was a corporate split with the heat exchanger manufacture and one of the offshoots greatly overstated their ability to weld stainless steel.
I have one IDEAL combi in my home. One year old. Plus I have three more combi IDEALS in three rentals. All around 3 years old. Hopefully someone will start supplying parts.
If we have to start replacing them what American made combi, wall hung is same size or smaller? I am thinking maybe Burnham. Or W.Mcl
possibly parts like flame rods or ignition wire will be available from an aftermarket supp.ier. The control boards and burner parts, fan motor, gas valve, maybe not.
Look at Lochinvar also. The Knight has been around for 20 years now. Solid company, good rep network and distribution.
Parts are available right now. I know the game plan for many wholesalers will be to part out units and sell some parts, while keeping others for their own customers as warranty parts. TT ran a "pre-season" sale this July and everyone is loaded up on boilers…. its bad news for the wholesalers who are stuck with units. Most of the big brands have long term support for their product. Lochinvar, VIessmann Burnham, Weil Mclain. none of these brands can really skip out of the US as they are either based here or their parent company is based in the US (viessmann owned by carrier).
@oreo123 Keep in mind when you are looking for parts that many of your Ideal boiler parts will probably have a direct equal in a Triangle Tube branded boiler.
Ideal is a large brand in the UK, so maybe some parts could be sourced from there or other markets.
It sounds like TT branded boilers to the US is what is discountinued
That's what I thought at first also but after looking into it Ideal NA also shutdown at the same time. I also could not find the Instinct model on their UK website, that was probably the most common in-warranty Triangle Tube model here in the US. So it seems parts really just depend….. on what model you have, and how your local dealers/wholesalers are handling things. We still haven't made a firm choice on what to do with all the leftover units, but we are definitely going to hold inventory for warranty work on the boilers we sold up in Northern Michigan. Hopefully some other wholesalers are doing the same but I kind of doubt it, we are all out a ton of money from this….
I suspect stranded and maybe soon to be obsolete inventory ends up on E-bay with some crazy high prices.
If you follow the E-bay consignee info it sometimes leads to a recognizable address of a wholesaler :)
If you have affordable shelf space I would not dump or bargin price parts or units you have. We still see MZ parts come out of hiding here on HH.
I know TT has numerous models and has changed HX manufacturers over the years, so one size fits all parts is not an option.
"…Lochinvar, VIessmann Burnham, Weil Mclain. none of these brands can really skip out of the US as they are either based here or their parent company is based in the US (viessmann owned by carrier)…"
Oh ye of little faith in the ability/willingness of corporations to do whatever they conclude will benefit their bottom lines. 😊
The above companies are all 100 year old companies though. I suppose any company can go under, but what TT parent company did was pull out of NA entirely, leaving wholesalers to hold the debt while they skip town. Carrier can't do that without the entire company going under, AO smith can't do that without the entire company going under. They would both be liable to still provide warranty parts for the duration if they were to close Viessmann or Lochinvar in the US. Groupe Atlantic tried to pull a fast one by no longer doing business in NA, it's apples to oranges. It's very different than country of origin.
Depends on legal details concerning how subsidiaries are structured. Long ago when General Motors was solid; a subsidiary defaulted on a lease obligation and mortgagees were unhappy.
- 15.8K Strictly Steam
