Plz help. I have a 1 pipe steam system and white smoke is coming out the chimney.
I have a 1 pipe steam system and an auto water feeder. The auto water feeder turns on almost everyday and adds more water. There is no leak whatsoever around the boiler and it works very well and efficient with the vaporstat on low pressure.
I see white steam coming out the chimney, which would explain why the auto water feeder keeps turning on. I know you guys are going to say i have a crack above the waterline, but is there anything i can do about this?
Begin searching for a Good Steam Contractor before it gets any colder.
Where are you located?
The first thing to do is determine for a fact that there is a leak and if so where. If there is a leak it's time to start saving up if you need to or replace if you can. In the mean time it's very possible that it can be sealed. I would attempt to seal it with Boiler Weld. This can very often give some breathing room.
so basically, just flood the boiler above waterline and see if it leaks? its been like this for years actually.
Personally, I stay far away from and sealant, that gets poured into the boiler. The sealant can't differentiate between a boiler hole and a return pipe...... If that sealant gets into the returns, you might be looking at thousands extra in repair costs.
steamdoctor, how do i know when the boiler is all the way to the top?
With the boiler off for an hour or so, just add water until you feel a distinct temperature change at the supply.
east meadow, NY
but doon't forget to restore the water level to where it belongs once yu have checked!
But… you have a leak.
There are a number of good steam people in your area — check the "Find a contractor" tab.
its been like this for years. what happens if i leave it, other than using more wateR?
Eventually it will die, and you'll have no heat.
Go here:
Consulting0 -
Another consequence of just letting it go for now is, with all that oxygenated make up water, you stand a good chance of corroding your steam pipes too.
When that happens you have to replace the boiler AND the pipes.
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
Well except that steam won't have the oxygen in it from the fresh water.
No, I would say you have a hole rusted through the boiler—not a crack
i had similar situation. thankfully my fix was "easy" (in a hard kind of way). 1 month later and the boiler is going strong with minimal new water intake (1 gallon in 1 month).
https://forum.heatinghelp.com/discussion/comment/1866987
Boiler replacement is VERY expensive (look up price of new boiler and x3 of it for labor).
Steam Heat YouTube videos:
https://www.youtube.com/@HeatingBlog0 -
" its been like this for years. what happens if i leave it, other than using more wateR? "
With steam going up the chimney your fuel consumption will be excessive as compared to what normal should be.
One Pipe System0
- 15.8K Strictly Steam
