Hot Water Boiler Rattling at Start of Heating Season
I have a 6 year old Dunkirk Series II model # DXL-125 hot water boiler that has been making a loud rattling noise and vibrating the pipes when it runs for the first few times each heating season for the last three years now. The whole boiler system was replaced, including the expansion tank, and they added a device which removes air from the incoming water supply so I don't have to bleed all of the radiators at the start of every heating season. I had the installing HVAC company out twice, the first time they said they had to see the problem happening to work on it, and of course it had already happened a few times already, and didn’t do it when I turned up the thermostat. They said don’t worry about it wait to see if something breaks. Is this a safety issue that I need to get fixed, or just an annoying glitch with the system starting each season?
How about posting some pics of the boiler and its near piping?
Bob Boan
The vent damper makes a squeaky door hinge sound when rotating. But you must be used to that. Its a simple boiler. Quiet circulator. Expansion?
I don't think it's a vent damper. The rattling is most pronounced at the regulator, and the entire gas pipe and regulator are vibrating loudly. See attached video.
WoW that is impressive !!! Sounds loudest at the gas valve. Kind of wonder what the burner flames look like when that is going on. While it is happening I'd probably disconnect the wiring connector at the gas valve to see if it instantly goes away.
One Pipe System1 -
Also while it is happening you could turn the gas valve to Off and see if it instantly goes a way.
One Pipe System0 -
Here you go, looks like others had the same issue. As long as the 24 Volts AC is good at the gas valve, I'm starting to be convinced it is a bad gas valve.
New Yorker boiler making buzzing noise.. New Yorker boiler gas valve replacement...
Utica boiler with noisy gas valve
https://youtu.be/4Rv0gdvZgnc
One Pipe System1 -
I didn't need to play the video. I heard it from my house. Call the installer back and play them the video. If it is the gas valve, I'd think the part would be covered under warranty. You might have to pay labor.
That's what's so frustrating. I played the video for one of their techs the second time they were here, and that's when he said it might be the solenoid in the regulator rattling, but he wasn't sure and said wait until something breaks. At this point I'm ready to use a different company just to get it resolved.
You need a more senior tech.
" he wasn't sure and said wait until something breaks " well in a way it is broke since it should not do that, ever. It may eventually get worse, vibrate more often or it may not.
At least he seemed honest with you " he wasn't sure "
Techs can get beat up either way, do nothing and not fix the issue, change the wrong part and charge the customer for it. The customer is still upset either way.
A more senior tech may have just changed the gas valve as the highest probable cause and that may have repaired it, at least for a while. It appears to me that style gas valve has that common issue, hopefully with the newer one that issue has been resolved.
One Pipe System0
