Warren Webster 02H thermostatic radiator traps
2»
  • I'll have to find my yellow pad that I did all of my radiator math on.
  • It appears that my boiler is sized properly. However with the sunroom and attic radiators shut off it is slightly oversized.
  • From my 1935 Webster catalog :
    mattmia2 Posts: 18,104
    so the check valves mean it can equalize the return to the boiler without equalizing the return main.
    109A_5 Posts: 4,500
    Do you have any of this equipment ?
  • Yes, it's still all in place and connected to the system.
    pecmsg Posts: 7,551
    edited September 2025
    Never Seize is a good product but use sparingly.
    you don’t need the grease and graphite in the boiler
    109A_5 Posts: 4,500
    Well, if it was my system, I'd definitely get a gauge or a home brew water Manometer on that system so you can see what is actually going on. Depending on that vent valve this system may normally fall into a vacuum at times, assuming the rest of the system is still air tight.
  • I'm very aware of using it sparingly. As a professional mechanic I know that it gets everywhere.
    109A_5 Posts: 4,500
    I used some Dow Corning 111 silicone grease on the threads and "O" ring of my B & J Bigmouth vent, the jury is still out.
    109A_5 Posts: 4,500
    One home brew water manometer as an example.
  • I also have Blue Monster pipe dope on hand
  • I believe the system is pretty tight as well. I did fix a couple of minor leaks at the radiators over the winter which were just loose nuts to one of the valves and one return trap and then the packing nut on the valve in the upstairs guest bathroom was loose.
    EBEBRATT-Ed Posts: 21,030
    Traps can fail open or closed. Usually open.
  • I was able to get all of the covers removed without too much trouble. I'll go through them and test the cage units and what I want to do too is bring them to work and bead blast the painted covers I think they will look nice with a bare finish
  • I am in a building that was built in 1916. It has a vacuum/vapor system. It has Warren Webster 2H traps. There are 100 radiator traps in the building. Just had a trap survey done and I had 2 trap elements bad. I use the Barnes & Jones elements and I replace a few elements every year but about half appear to be original to the building, so they used to make the traps to last a long time! If you replace an element that screws out of the cap, you need to remove the seat and that takes a 7/8" socket.
    i don't think any of that is a standard trap, i think those are all special vapor system parts.
