How much rust...
… is enough to panic?
Need to replace pilot assembly on a Rheem gas water heater. Found a heapum pile of rust particles on top of the burner from the heat exchanger. What I can see on the bottom away from the burner just looks like corrosion from condensation dripping from the exchanger. Though one spot on the side does seem a little concerning.
Everything is bone dry. At least when it is cold.
Two family house. Units are 11 years old.
Water heaters and the furnaces are getting close to end of life but in what I hoped, replacement would be next year after the coming heating season.
What do you think?
No one can know for sure how long it’s gonna last, but as Larry said, I’ve seen much worse.
Bob Boan
got a pic of the entire tank?
That is an odd looking seam and tube pic
Hi, I only use magnesium for household usage. Rheem uses magnesium, but their anodes have a resistor built into the hex head of the rod. I like to use rods that show the weld bump top center of the 1-1/16" hex head. This way I know there is no resistor. I'm seeing that flex anodes cost a bit less than solid rods, maybe because of shipping. Get as large a diameter rod as you can find. Unscrewing the old rod can be "fun". 🤯 Another option is to install powered anodes. These could be transferred to new tanks if ever needed. 😇
Yours, Larry
@Larry Weingarten Power anodes? cool. That's the way to go.
@pecmsg you called it…
After replacing the pilot assembly, fired her up. All good. After it reaches temp and shuts off I hear, Drip, sizzle……. drip sizzle…..
Great. Shut off water and gas, went out for a drink while it cooled off. (not that I needed the excuse at this point). After cooling, when it was taken apart, dry?!
Opened the water back up, waited. Silence. Reassembled, wasted another gasket, fired up and same deal. After reaching temp and shutting off, the slow drip and sizzle as it hits the burner. It only lasts a minute or so and then stops. I assume it's leaking while firing but not fast or loud enough to hear.
So apart from it's time to replace the water heater, any clue what gives? (just for curiosity's sake)
Thanks for all the help.
Michael
