Boiler wiring tips
waspring
waspring Member Posts: 1
hello I’m a new/old plumber getting into the service side of things I’m looking to learn boiler wiring any tips? I have limited knowledge of electrical any advice is appreciated thx
    Jamie Hall Member Posts: 27,003
    Read the manual. Read it again.
    Use coloured wires, and use them with the colours the manual suggests.
    Use the correct types and sizes of wires.
    Keep it neat.
    mattmia2 Member Posts: 15,996
    understand electricity. understand how like bell and switch and 3 way light switches and stuff like that works then it will make sense when you look at a schematic.
    109A_5 Member Posts: 3,684
    edited August 2025
    Study as many applicable schematics / wiring diagrams as possible. Read the notes and learn the symbols. Study the logic of the circuit.
    learn as much about basic electricity as possible.
    Learn how to use a multi-meter.
    Learn troubleshooting strategies.
    Learn applicable safety.
    Get stuck… Ask questions.
    Learn what not to do.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,464
    Go very slowly and know when you need to bring in help. It takes years to get really good. Mad Dog
    EdTheHeaterMan Member Posts: 11,752
    Step 1 Understand the basic electrical circuit. Source > Control > Load > Return path to source
    AD_4nXf_xaYSgzoslz0ZznYRFApr14n6AcTmqiCEDTyTJJS8DYhzLAvjFUx3BdXf9sF6Ax2tgbjieSK2WYpqATJ2eafS0R0rmVtd68x4zVWLo1vDRbXDIZlv7vVOUTppCxE1NAHSE3jv?key=IJVBbYG7j0o4xpWus040OCO9
    This is a basic electrical circuit.
    1. Source = two 1.5 volt batteries
    2. Load = light bulb
    3. Control = manual switch
    4. Return path to source
    Note that the load and control can be reversed. The load can be on the Source side or the Return Path side of the circuit.
    From that basic understanding of electricity, you can build any analog electrical control circuit to operate a boiler.
    mattmia2Alan (California Radiant) ForbesScottSecor
    hot_rod Member Posts: 27,066
  • ratio
    ratio Member Posts: 4,202
    Break the big problems down into smaller problems. Most things, even though they are interrelated, can be thought of independently.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,034
    I'll add, don't trust what you find in the field. I've seen green wire used for power. Assume it's live, and test. 🤓
    Yours, Larry
    EdTheHeaterManold_diy_guy
    Oh yeah. Never ever assume that any given wire is not live, never mind carrying power. Not only turn off the power at what you think is the breaker… but use a non-contact voltage tester (they're really cheap). The breaker or fuse you thought was the one… just might not be. Ask me how I know…
    Also… keep the fuse, if it is a fuse, in your pocket while you work. And put a huge note on a breaker, if it's a breaker and doesn't have a lockout/tagout (most residential circuits don't). So some idiot doesn't turn it back on and light up your life…
