Tamper free switches
Hey Wallies!
I did a job recently that got inspected by the insurance company they wanted three switches outside of the boiler room for safety. I get it, but this building has many tenants who like to play with switches. Does anyone know of a tamper free switch that would pass an insurance inspection? Technically he approved it but we want to send proof it’s done.
Thanks
tom
Montpelier Vt
Good question. I mean the switches are for safety to shut the boilers down so if they are tamper resistant they can't be shut down. This is part of the ASME CSD-1 (i think it is called) for boiler controls. Switches must be outside all boiler room entrances for commercial boilers.
The only thing I could suggest is to make a box to mount the switches in with a glass front (like the old fire alarms) so they have to break the glass to shut down the boilers.
But then the person that breaks the glass will sue if they get cut.
Something like this:
Kinda defeats the purpose of a safety switch…
and no one is replacing the glass after the first time.
After inspection no one will care.
Hang a fake camera next to the switches with a sign " When switches are opened your on candid camera"
or "switches monitored by alarm company"
I appreciate the points, and we understand the possibilities. It's a bummer we have to even think about this.
Thanks for ideas
Tom
Montpelier Vt0 -
I don't know if you're allowed to have 2 disconnects in series but if you are, you could put a dpdt switch outside the door with an alarm on the second pole in the off position so that it would be sufficiently annoying to leave it in the off position in a non-emergency and put a second switch at the boiler for service work.
How much room is there inside the boiler room? Is there enough room to place a one foot vestibule just inside the boiler room, or just outside the boiler room in order to make the switch pass inspection outside of the boiler room door but still out of public area?
2 -
That's a good idea @EdTheHeaterMan if you can get the various inspectors to agree on what a boiler room is and what the fire rating of the vestibule should be. That may be the best option
I think the in case of fire cover may be ok. It stops a lot of people from pulling the fire alarm!
The boiler room is big but the customer is tapped out. Lets start with simple covers, and see how it goes.
Thanks AllTom
Montpelier Vt0
- 123 Chimneys & Flues
