Support steam pipe with split ring hangers
branimal
Member Posts: 260
Can I support a horizontal run to a radiator with a split ring hanger? I'm wonder how expansion and contraction cycles will be impacted by such rigid support.
Thanks
Over the insulation? Real risk of the pipe sagging with time…
I Assume proper under support!
not if you use those little asbestos blocks that made owens corning go bankrupt
Clevis hangers all day for a better outcome.
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
- 119 Chimneys & Flues
- 76 Pipe Deterioration
