leaky sink trap connection
Usually a molding defect in the sealing surfaces of the trap or the compression ferrule or the nut but it could also be various forms of operator error like cross threading the nut or leaving a burr on a metal component or damaged surface of the tubing. The metal components can get dented on the sealing surfaces and have similar problems. The washers rot out after some period of time.
Actually there are lots of ways those things can leak. I think I've found most of them the hard way…
Depends on where it's leaking, though. The drain fitting to the basin? The slip joint (if used?)? The p-trap connections (that's a common one)…
But if all the sealing rings are in place right side up, and nothing is bent or dented…
So do you guys change the works or do you fiddle until there's no drip?
Me? Depends. If it's new work — like a new sink — I have pretty well gotten to the point of changing what's leaking. Between warped sink outlets and oddly oval pipes and defective seal rings… aargh. Trade off between time to trouble shoot and price of the parts. On old work, however, I'll take things apart and see how it was meant to work in the first place and then fiddle and fix…
Plastic never rots out. Can't really say that about brass.
The slip brass fittings are not the best. I usually prefer metal over plastic but not in this case.
Brass comes in different weights too, the heavy stuff is expensive.
Expensive but does the job
Hi There
Even with low water pressure, sink trap leaks or fitting issues often come from misalignment, poor-quality parts, or worn washers— its not the water pressure itself.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
