leaky sink trap connection
jumper
jumper Member Posts: 2,511
I saw a youtube of a professional plumber having trouble connecting sink trap. I remember have same problem sometimes. With so little pressure why is there a problem sometimes?
    mattmia2 Member Posts: 15,983
    Usually a molding defect in the sealing surfaces of the trap or the compression ferrule or the nut but it could also be various forms of operator error like cross threading the nut or leaving a burr on a metal component or damaged surface of the tubing. The metal components can get dented on the sealing surfaces and have similar problems. The washers rot out after some period of time.
    Jamie Hall Member Posts: 26,993
    Actually there are lots of ways those things can leak. I think I've found most of them the hard way…
    Depends on where it's leaking, though. The drain fitting to the basin? The slip joint (if used?)? The p-trap connections (that's a common one)…
    But if all the sealing rings are in place right side up, and nothing is bent or dented…
  • jumper
    So do you guys change the works or do you fiddle until there's no drip?
    Me? Depends. If it's new work — like a new sink — I have pretty well gotten to the point of changing what's leaking. Between warped sink outlets and oddly oval pipes and defective seal rings… aargh. Trade off between time to trouble shoot and price of the parts. On old work, however, I'll take things apart and see how it was meant to work in the first place and then fiddle and fix…
    Larry Weingarten
  • Hard to say without watching the video. As much as I love an 18 gauge p-trap, the cheap, plastic ones go together much easier and seem to last longer.
    mattmia2GGross9326yssh
    Plastic never rots out. Can't really say that about brass.
    EdTheHeaterMan Member Posts: 11,748
    I FIND THAT IT DEPENDS ON HOW SERIOUS THE LEEK IS
    Of course this one looks pretty serious.
    GGrossPC7060
    EBEBRATT-Ed Member Posts: 19,881
    The slip brass fittings are not the best. I usually prefer metal over plastic but not in this case.
    Brass comes in different weights too, the heavy stuff is expensive.
  • 8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
    EdTheHeaterManLarry WeingartendelcrossvPC7060
  • delcrossv
    delcrossv Member Posts: 2,189
    I do notice there is a big difference in the compression nuts I get from my plumbing supplier and HD .
    Sloppy tolerances and too short threads equals problems snugging them up.
    Mad Dog_2
    pecmsg Member Posts: 6,877
  • Intplm.
    Intplm. Member Posts: 2,906
    Pipe dope on the plastic/nylon gaskets, tighten hand-tight, and where plastic meets plastic. No leaks.
    PC7060
  • plumbj
    plumbj Member Posts: 3
    Hi There
    Even with low water pressure, sink trap leaks or fitting issues often come from misalignment, poor-quality parts, or worn washers— its not the water pressure itself.
