Mixed freon
I don't know. have they finally fixed that problem with post about 2005 systems leaking and pre 2005 systems lasting for 50 years until something rusts out?
they really don’t care.
No and it doesn't matter!
The old refrigerants are going By By you can only get the newer blends. Are they better, No but thats what the Gouberment allowes!
If it's fixed and no longer leaking I would recover the charge, replace the filter drier, evacuate and recharge it with R407C or whatever R22 replacement refrigerant is compatible with the oil in the system. I don't think you need to flush the system with anything besides the nitrogen that's used for pressure testing. R22 would be ideal if you happen to have it but you can probably use R407C, R22D or something else.
2 -
and once you get certified and has that 30 pound drum of refrigerant where does he get his recovery machine, recovery tank, vacuum pump, on and on! All that cost a lot of money
You can supply it to the tech that is charging it. Or do it yourself after you evacuate it to take a slightly political side step. No one is enforcing the law on small systems.
Plenty of partial tanks on facebook marketplace too.
Yup. recovery machines , tanks and vac pumps all over Facebook.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
