Is this a house trap?
124»
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,537
    The repiping I saw was in PVC with no House Trap…fill me in…??? Mad Dog
  • bdp1999
    bdp1999 Member Posts: 60
    This one is at my house. Getting both dont since traps are obsolete and companies won't camera or hydro just if the house has a trap.
  • bdp1999
    The only problem now is that the pipe with the wye seems to be the main drain for the house. When flushing and running water, it all seems to go through the castiron pipe. The one that had the trap doesn't seem to drain out anything. Could it be the downspouts drain? It contained a lot of roots coming from under the house.
  • bdp1999
    It also had a 5" that converted into a 4" at the trap.
    mattmia2 Member Posts: 16,606
    what started this whole project? was the sanitary sewer backing up?
    there is likely drain tile around the perimeter of the foundation either outside or inside the wall that comes together under the basement slab and either goes out to a separate storm sewer under the street or possibly combines with the sanitary sewer in to a combined sewer under the street. if it is a combined sewer you may be required to replace the stormwater portion with a sump pump that moves the water outside depending on local regulations.
  • bdp1999
    edited May 2025
    It must combine somewhere outside the house and inbetween the street, but why would the stromdrain have a trap and not the sewage line? I have had root issues, snaking it 1-2 times a year. Our city eleaviated stromdrains years ago. So they've all been sealed. I hear they usually crack underground and cause root issues. That might have been what I partially removed.
    All an all, the problem is outside of the house and the house trap has been removed and replaced with a sanitary pipe. So there should be no problem using a camera or hydro jet.
    if it is a combined sewer the trap might be before it connects to the sanitary sewer so sewer gas doesn't back up in to the drain tile and downspout leaders. the stormwater part is very likely connected to drain tile around the footing, not just downspout leaders.
  • bdp1999
    The Trap is what I removed. Doesn't seem to be before the pipe connect.
    presumably they go out under the wall toward the main sewer?
    is the pipe coming from under the floor where the drain tile around the footing connects together?
  • bdp1999
    edited May 2025
    No, that goes to the floor drains and other utilities.
  • Mad Dog_2
    In NYC, we always trap, roof rain leaders, conductors & gutters, yard & area drains, i.e., all Storm Water, clear condensate, et cetera that tie in to a Sanitary or soil line. Mad Dog
  • leonz
    leonz Member Posts: 1,807
    Have you called Bison Plumbing as I suggested to solve this issue??
  • bdp1999
    Why wouldn't the sanitary be trapped?
    edited May 2025
    the sanitary has a trap on each fixture. the stormwater piping just connects directly to the tile and the downspout leaders
    i have also seen floor drains connected to the stormwater system that didn't appear to have traps.
  • ChrisJ
    ChrisJ Member Posts: 17,333
    In most areas the house and it's vents are used to vent the sewer or septic. This isn't the case in NYC.
  • PC7060
    PC7060 Member Posts: 1,793
    that is a clean excavation. Looks like an archeology dig!
    bdp1999
  • Mad Dog_2
    Commercial roof drains are not trapped...no need to...clear water waste. Mad Dog
  • bdp1999
    Refill and concrete pour on job one.
    1000009108.jpg 1000009109.jpg There was an error displaying this embed.
    PC7060
  • Mad Dog_2
    You feathered the C-ment in real good...nice work. Mad Dog
    PC7060
    pecmsg Member Posts: 7,034
    Your Hired! 👌
    PC7060Mad Dog_2
  • bdp1999
    Second job filled.
    Thanks everyone!
