Temporarily Moving Compressor For Yard Work
Hi we have this old compressor unit that will have to be moved about 5ft forward to accommodate brick removal from the ground. Easiest way would be have AC guy and detach the power and refrigeration lines for a few months; then I thought perhaps —since hot season's coming on—the lines could be extended a few feet to keep the AC running. Not sure about the safety issues possibly posed by this.
Yeah I figured—probably best to pick the time to move the unit as close to the time of the yard work as possible and then re-install. We can do without AC for a few weeks if we have to. As old as the unit is don't want to throw good money after bad. I think the detaching and re-attaching should be done by AC pro given the high voltage and potential refrigerant leakage.
How extensive is the yard work? Let me Guess…. you want to remove the old pavers that have that "old town" look that other folks would kill for, right?
Can you do the yard work up to the location of the condensing unit then move it about 3 feet without disturbing the line-set, then placing it back in the same location when the yard work is completed?
If it is going to be concrete work BE SURE TO COVER THE UNIT WITH A TARP OR CONSTRUCTION PLASTIC. Wrap it up like a Christmas present so the concrete does not splash on the fins. You will never get that stuff off once it dries up and sets.
4 -
It's a crap shoot moving an old unit like that. Even using best practices with evacuation, etc some units just don't last long after. I've had some work just fine while others had sort lives after. I always quote the removal and the replacement price to give the customer all the information. Another gotcha this yeah is new equipment with 454B. Make sure the contractor has 454B on hand to adjust the charge as needed if you go for a replacement. There's somewhat of a shortage on that right now. I've been waiting over a month for it come back in stock
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
2 -
Thanks all. Some great constructive ideas there and warnings. The paver area nearby will be returned to dirt for planting but the AC will always have to sit atop a hard surface, pavers or concrete. So now as I think about it seems wiser to leave it alone right now and still have AC for summer, replace it when it dies, reframe with new pavers and THEN put a concrete pad for the new compressor. Thanks all for the input.
3 -
It is a bit of a hassle but @EdTheHeaterMan and @mattmia2 suggestions of working around it are solid and you could keep it hooked up and going, and just move it the minimal amount and get your yardwork done too.
In your shoes, I would remove the brick right up to it on each side. Then get some precast 18x18, rock one side up at a time and slip those paver blocks in after removing bricks and carefully grading a sand bed. Then restore around it and enjoy. Until it craps out.
1
