Oil to electric help
Hailey
Hailey Member Posts: 6
hello I am looking for some advice and some help. We bought our home in 2011 and there was a new boiler at the time of purchase . We have a coil that needs to be replaced for $1300 and now it’s a 13-year-old boiler( and a crappy one from what I understand from our heating guy Slant Fin)I also need a new oil tank because that was original to the home and it’s very old and starting to leak. However, here’s the catch we used two pellet stoves to heat our entire 4000 square-foot home. The only reason we’ve kept the boiler running is to heat water and to heat one zone that is closed off from the stove so that the lines don’t freeze during our winters. Here’s where I need help …we’ve come to a point where i have a huge amount of money that needs to be thrown at this heating system to at the moment. We don’t use this heating system for what it’s intended. How do we convert over to some type of maybe electric system? One idea is just putting an electric water heater in. Cutting off all of the oil supply and basically installing a hardwired electric heater in the zone that needs extra heating in the winter. Can someone please throw in ideas here for us? I know it’s kind of complicated but at the same time pretty straightforward thanks so much.
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,241
    edited April 2025
    You can swap in an electric tank and install an electric baseboard in the room easily. That’s straightforward.
    The rest of the house becomes complicated. You can exclusively use the pellet stoves there. You could also try to replace the forced hot water system with an air to water heat pump or an air to air heat pump. Or decide to replace with electric baseboards. All have their own pros and cons, but to your initial domestic hot water + one zone question, that’s easy.
    Hailey
  • Hailey
    mattmia2 Member Posts: 16,746
    Is the tankless coil leaking or just the gasket for the coil? If the coil is leaking the boiler will slowly gain pressure as the domestic water leaks in.
    If it is just the gasket, someone competent should be able to replace that inexpensively and easily. retorque the bolts after a year or so and it won't start leaking like that gasket did.
    Might be cheaper to fix it/blank it off and go to an electric water heater if you have the electric service for it because heating the boiler all summer just to make hot water is pretty inefficient.
    As far as the space heating, do you have gas in the house? A gas power burner on that boiler might be better than replacing the oil tank if you have gas available.
    HaileyEdTheHeaterMan
    Steamhead Member Posts: 18,494
    @mattmia2 said "As far as the space heating, do you have gas in the house? A gas power burner on that boiler might be better than replacing the oil tank if you have gas available."
    This. I can tell you the Intrepid boilers run nicely with Carlin EZ-Gas or Midco EC burners, properly tuned of course.
    Consulting
  • Hailey
    No gas lines to the house or in this part of town where I live. Boiler has been maintained yearly by the same service person who gave us the quote today for the coil.
    pecmsg Member Posts: 7,055
    the same person that says he doesn’t like them, that doesn’t put up a few red flags?
    mattmia2LRCCBJdelcrossvMaxMercy
    keep the oil.
    Get heat pumps for the mild weather.
    HaileyMad Dog_2
  • Kaos
    Kaos Member Posts: 865
    A couple of things we need to figure out. First is your heat load. Roughly how many Therms of pellets you are burning in your stove and how efficient are they?
    What is your local electricity cost? How big is the existing service? Do you have any big electrical loads like a pool / hot-tub or EV charger?
    Insurance company will want a thermostat controlled heat source, so if you replace the boiler with an electric unit, it needs to be able to heat the whole place. This can usually be done if your heat loss is reasonable and you have the capacity on your panel.
    EdTheHeaterMan Member Posts: 12,155
    There have been some interesting things mentioned here.
    1. Why does the coil need to be replaced? describe the symptoms that you are experiencing that lead to the decision by the servicing company to recommend that repair.
      1. The coil has an internal leak and is causing the relief valve on the boiler to release water on a regular basis
      2. There is nothing wrong with the coil and that little bit of crust around the gasket is the reason you need to address the coil. (not a good reason to replace the coil)
      3. You asked about the crusty build up around the gasket and the technician took that as an opportunity to sell you something
    2. Can you replace the oil tank with a propane tank?
      1. They usually are offered for free when you sign up with the propane company, but the propane will cost more per gallon.
      2. You can purchase a larger propane tank and have it buried or above ground.  When you own your tank you can shop for the best propane prices or sign up with a propane company for automatic delivery.  Then you can install a Midco power burner in that SlantFin boiler.  I have worked on several boilers like yours in my career and have known them to last for well over 30 years.
    3. You can abandon the tankless coil if it is truly defective and put those $$$ towards a more efficient water heating source, like an indirect that runs off of the boiler (but uses much less fuel) or a stand alone propane water heater (since you have a new propane tank)
    4. You can abandon the entire boiler and radiator system and install a new 250 AMP electric service to accommodate electric baseboard radiators that will qualify as a central heating system for mortgage, resale value, and insurance purposes, even if you never use them, because you are using less expensive pellets.
      1. But don’t get injured or old while you are living in that home with all electric heat.  If you are no longer able to do the pellet thing as a result of being 90 years old or are hurt in a car accident.
      2. Make sure that your son never moves out of the house if #4a. happens. then he can keep feeding the pellet stoves
    I have been repairing and installing all kinds of HVAC systems my entire adult life.  I never thought about what might happen if I were stuck in a wheelchair (like I am now).  So I had to sell my business and retire, move to another state where the cost of living is much lower, and I have a heat pump that is about the worst heating system I have ever lived with.  But that won't happen to you so make your decision as if nothing will ever go wrong with your life.  That’s my advice.  (NOT!)
    Haileymattmia2Mad Dog_2Robert_H
  • Hailey
    @EdTheHeaterMan
    a. It’s leaking water
    We literally keep this whole thing going just to heat one zone so it doesn’t freeze and of course it froze when we lost power 🤪 which is when we think air got in the line and caused this mess. Propane is an option.
    Jamie Hall Member Posts: 27,359
    Got that. Bu7tn that's vague. Is it really @EdTheHeaterMan 's 1.a.? If it is, the best and easiest option is to simply stop using the boiler for domestic hot water, cap the lines going to the coil, and install a conventional electric water heater.
    This is something even the dimmest plumber should be able to do in an afternoon…
    MaxMercyethicalpaul
  • Jon_blaney
    Jon_blaney Member Posts: 335
    In my experience, oil will be the cheapest heating source if natural gas is not available. Stay with oil. Fix the boiler, get a new oil tank. If you must replace the boiler consider using a oil fired water heat for hot water and the small heat zone. Use a heat exchanger connected to your existing hydronic zone.
    hot_rod Member Posts: 27,446
    edited April 2025
    It is helpful to use fuel cost data in your specific area, I lived in the midwest for 24 years and LP was always the less expensive fuel when compared to fuel oil. LP prices in the summer and early fall were always the lowest. So with additional tanks you can load up, or do a pre-buy to lock in a price for the season.
    LP equipment is available with 90% + efficiencies when designed and applied properly. A2WHP over 300% efficiency is possible. The number crunching is important when considering required SWT, to maximize condensing or heat pump technology.
    The EIA site allow you to go back 20 years or more to compare various energy costs.
    Once you have actual delivered cost, this site is easy to use to make the $$ comparison
    https://coalpail.com/fuel-comparison-calculator-home-heating
