Do shower pans fail?
jumper
jumper Member Posts: 2,516
Seen lead; galvanized; flexible membranes; pitch pot.
Any opinions?
  • HydronicMike
    HydronicMike Member Posts: 314
    Don’t know anyone still doing lead, but membranes seem to be the standard around here.
  • kcopp
    kcopp Member Posts: 4,659
    If water runs through it, it can fail. They dont call it the Universal Solvent for nothing…
    If the details on any shower are not done proper they can/ will fail.
    I have seen many membrane systems fail.
    Its all in the details!
    Tried and true method I have seen is Copper…. Not been part of one of those installs in many years.
    Mad Dog_2
  • delcrossv
    delcrossv Member Posts: 2,194
    Lead under tile or precast around here.
  • PC7060
    PC7060 Member Posts: 1,772
    edited April 2025
    yes pans do fail.
    each type has its own failure mode
    rubber membrane with pre-slope and top mud layer typically fail due to nails through rubber within 8" of floor. This is especially problematic with wood curb as the leaks cause wood to swell over time rupturing the curb. Of course by this time the water has caused damage to subfloor was well
    fabric water proofing membranes such as Schluter Kerdi over mud or foam base are very good (gold standard IMO) but failures occur when wood is used for curb structure and the glass door installers put screws through the water proofing causing curb failures as described above.
    Metal pans such as copper and lead were common in northeast and when done properly are very good but expensive. In recent years, this methods seems to be surpassed by the fabric water proofing membranes.
    Hot mop tar sealing is a west coast thing and is a mess IMO.
    And then there’s Florida where up until recently no water proofing was applied to shower floor on slab on grade homes; any water that didn’t go down drain just seeped though tile grout and into the sandy soil. 🙄
    So just like boiler there’s 1 million ways to screw up something particularly when you don’t read the manufacturers installation instruction.
    Recommend johnbridge.com as an excellent resource for all things tile and water proofing. The picture below has a foam curb with mud base sealed with Schluter Kerdi. Walls are Kerdi board (foam). Great products
    Mad Dog_2delcrossv
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,494
    edited April 2025
    I've done most all mentioned above. The quality of the Sheet lead available today is atrocious...loaded with iron. Copper are very nice and take super tight folds and corners, but you need a very good solderer.
    A very good choice is a Pre-made chigh qaulity such as a Jacuzzi brand. Terrazzo bases are also very durable. Mad Dog
    PC7060
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,057
    Hi, and yes, all pans can fail, even the pre-made ones, if the person using it is heavy enough to crack it. I'd only use pre-made upstairs, as they seem to hold up best. With hot mopped and galvanized, I've had to fix the floor joists, they were so badly rotted. The water wall of a shower has many ways it can leak too, so I always try to give access.
    Yours, Larry
    hot_rod Member Posts: 27,211
    PVC membrane is the go to around here. It is all I have ever used.
    The floor needs to be sloped with a mud sent to the drain, then the pan goes down.
    The seal to the clamping ring is important also.
    We had to fill them to the curb with water for an over night inspection.
  • psb75
    psb75 Member Posts: 1,113
    Yes! Pans of all types will potentially leak. Best brand-names of whole systems: Schluter, Kerdi, Wedi. The Germans have figured it out. Expensive, but worth every penny. Thick membranes, metal pans, hot-mopping, and cement board are generally methods of a by-gone era. The shower walls, pan and curb MUST be waterproof BEFORE the tile goes on.
    PC7060delcrossv
  • delcrossv
    Used Kerdi for a tub/shower redo. Holding up great. Thought using fuzz covered foam was nuts, but I stand corrected.
    PC7060
  • Arrxiemen
    Arrxiemen Member Posts: 1
    I’ve seen most failures come from bad prep, not the material. A solid preslope, tight corners, and careful drain work make flexible liners and old-school pans hold up for decades.
    the seal around the drain is another leak point. Plumbers silicone the pan to the drain and plug the weep holes, sometimes
  • HomerJSmith
    HomerJSmith Member Posts: 2,769
    @kcopp, "… they don't call it the Universal Solvent for nothing." I thought gasoline was the Universal Solvent.
    EdTheHeaterMan Member Posts: 11,930
    Only when the leak!
  • Intplm.
    Intplm. Member Posts: 2,974
    lead pans are great. The newer schlooter (is that how it's spelled?) and other similar products work wonderfully. All have the chance to fail. Installed properly the chances of failure are slim.
  • Mad Dog_2
    Lead pans were excellent until the purity took a dive.…Mad Dog
  • PC7060
    i’ve done several showers with mud beds and walls covered with Schulter Kerdi waterproofing. Very nice product, but that along with the tile takes skill and attention to details that is hard to find.
    Honestly anymore I recommend people by a fiberglass pan and use half inch solid surface panels (Coriane) for the walls. Clean look and pretty much idiot proof.
