Do shower pans fail?
jumper
jumper Member Posts: 2,597
Seen lead; galvanized; flexible membranes; pitch pot.
Any opinions?
  • HydronicMike
    HydronicMike Member Posts: 401
    Don’t know anyone still doing lead, but membranes seem to be the standard around here.
  • kcopp
    kcopp Member Posts: 4,713
    If water runs through it, it can fail. They dont call it the Universal Solvent for nothing…
    If the details on any shower are not done proper they can/ will fail.
    I have seen many membrane systems fail.
    Its all in the details!
    Tried and true method I have seen is Copper…. Not been part of one of those installs in many years.
    Mad Dog_2
  • delcrossv
    delcrossv Member Posts: 2,204
    Lead under tile or precast around here.
  • PC7060
    PC7060 Member Posts: 1,866
    edited April 2025
    yes pans do fail.
    each type has its own failure mode
    rubber membrane with pre-slope and top mud layer typically fail due to nails through rubber within 8" of floor. This is especially problematic with wood curb as the leaks cause wood to swell over time rupturing the curb. Of course by this time the water has caused damage to subfloor was well
    fabric water proofing membranes such as Schluter Kerdi over mud or foam base are very good (gold standard IMO) but failures occur when wood is used for curb structure and the glass door installers put screws through the water proofing causing curb failures as described above.
    Metal pans such as copper and lead were common in northeast and when done properly are very good but expensive. In recent years, this methods seems to be surpassed by the fabric water proofing membranes.
    Hot mop tar sealing is a west coast thing and is a mess IMO.
    And then there’s Florida where up until recently no water proofing was applied to shower floor on slab on grade homes; any water that didn’t go down drain just seeped though tile grout and into the sandy soil. 🙄
    So just like boiler there’s 1 million ways to screw up something particularly when you don’t read the manufacturers installation instruction.
    Recommend johnbridge.com as an excellent resource for all things tile and water proofing. The picture below has a foam curb with mud base sealed with Schluter Kerdi. Walls are Kerdi board (foam). Great products
    Mad Dog_2delcrossv
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,704
    edited April 2025
    I've done most all mentioned above. The quality of the Sheet lead available today is atrocious...loaded with iron. Copper are very nice and take super tight folds and corners, but you need a very good solderer.
    A very good choice is a Pre-made chigh qaulity such as a Jacuzzi brand. Terrazzo bases are also very durable. Mad Dog
    PC7060
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,182
    Hi, and yes, all pans can fail, even the pre-made ones, if the person using it is heavy enough to crack it. I'd only use pre-made upstairs, as they seem to hold up best. With hot mopped and galvanized, I've had to fix the floor joists, they were so badly rotted. The water wall of a shower has many ways it can leak too, so I always try to give access.
    Yours, Larry
    hot_rod Member Posts: 28,017
    PVC membrane is the go to around here. It is all I have ever used.
    The floor needs to be sloped with a mud sent to the drain, then the pan goes down.
    The seal to the clamping ring is important also.
    We had to fill them to the curb with water for an over night inspection.
  • psb75
    psb75 Member Posts: 1,158
    Yes! Pans of all types will potentially leak. Best brand-names of whole systems: Schluter, Kerdi, Wedi. The Germans have figured it out. Expensive, but worth every penny. Thick membranes, metal pans, hot-mopping, and cement board are generally methods of a by-gone era. The shower walls, pan and curb MUST be waterproof BEFORE the tile goes on.
    PC7060delcrossv
  • delcrossv
    Used Kerdi for a tub/shower redo. Holding up great. Thought using fuzz covered foam was nuts, but I stand corrected.
    PC7060
    the seal around the drain is another leak point. Plumbers silicone the pan to the drain and plug the weep holes, sometimes
  • HomerJSmith
    HomerJSmith Member Posts: 2,797
    @kcopp, "… they don't call it the Universal Solvent for nothing." I thought gasoline was the Universal Solvent.
    Only when the leak!
    old_diy_guy
  • Intplm.
    Intplm. Member Posts: 3,115
    lead pans are great. The newer schlooter (is that how it's spelled?) and other similar products work wonderfully. All have the chance to fail. Installed properly the chances of failure are slim.
  • Mad Dog_2
    Lead pans were excellent until the purity took a dive.…Mad Dog
    Intplm.
  • PC7060
    i’ve done several showers with mud beds and walls covered with Schulter Kerdi waterproofing. Very nice product, but that along with the tile takes skill and attention to details that is hard to find.
    Honestly anymore I recommend people by a fiberglass pan and use half inch solid surface panels (Coriane) for the walls. Clean look and pretty much idiot proof.
    delcrossv
  • RascalOrnery
    RascalOrnery Member Posts: 150
    Is there any danger in doing both a drain and dry style shower? As in PVC liner, dry pack slope and then kerdi on top? As in, first intention that the kerdi drains all the water to the drain, and as a second safety have the PVC liner to protect the floor. At least if one fails the other has minimal exposure to water to deal with? Or am I all green there?
    The mud pack should be sloped, then a pan put over that
    There are a number of ways to do this. Some tile setters are using a liquid pan material, also
    It really comes down to which method your tile setters prefer
    The key is doing it correctly, more so than the product.
  • delcrossv
    This is what we're doing with 4 other units that aren't in the "historic" building. Cut , glue, caulk, done.
    PC7060
  • jumper
    Perhaps some leaks originate with poor detail work around the drain? Good roof deck drains use double funnels.
  • pumpcontrolguy
    pumpcontrolguy Member Posts: 69
    Definitely still lots of lead pans still getting done in NYC.
    But like others said, water has a way of finding its way everywhere we don't want it.
