sizing copper pipe
need to run line from propane tank to barn 160' 300000 btus -this is line from tank to regulator what size line is needed
Fisher Controls handbook sizing chart has 1/2" OD type L, will carry 400,000 BTUH a distance of 175'.
This is 2 psig pressure drop with 10 psig reg at tank. FWIW
Its amazing how small propane piping can be. Propane packs a high btu punch. Butane is even higher. Mad Dog
If you go by my generators engine natural gas provides 10-20% less power than LP.
Here' goes some high school chemistry.
One mole(or more simply the same number of molecules) of any molecule in gas form has the same volume at a given temp and pressure.
Methane is CH4. you burn it and you get 1 carbon dioxide molecule and 2 water molecules.
Propane is C3H8. you burn it and you get 3 carbon dioxide molecules and 4 water molecules.
each of those reactions releases a defined amount of energy so burning a given volume of propane releases almost 3x as much energy.
A piece of equipment running propane vs methane with no modification other than the fuel and air metering has a lower input and lower output burning propane than when it is burning methane. I don't know why this is but I suspect that it is because the propane burns at a lower temp so less work can be done with a given volume and surface area.
Pardon the possibly stupid question, but how could two different units of volume (cu ft vs gallon) have different ratios of energy like that?
2516 to 1030 = 2.44
91,452 to 85,098 = 1.07Are the gallon units in liquid vs the cu ft units being gas?
Did we lose the op completely? I think the why does the same equipment fired with propane have a lower capacity than when fired with methane is a @Tim McElwain level question because it isn't the energy content of the gas, at least not directly.
