Your favorite Heating Help questions
jesmed1
jesmed1 Member Posts: 1,468
edited March 2025 in THE MAIN WALL
The ongoing debate about use of SharkBite fittings made me laugh, because it seems there a number of "hot button" questions that are guaranteed to spark a lively debate here. Here are some of my favorite questions, because they seem to have the highest entertainment value:
1.How large a pickup factor does my steam system really need?
2. What is the actual efficiency of a cast iron boiler?
3. How much money will a new EK 2000 save me?
4. Can I use a SharkBite fitting?
And @EBEBRATT-Ed added some of his favorites:
What type of pipe dope do I use?
How do I add a "C" wire to a thermostat?
My burner will not start, what is wrong with it.
Who makes the best boiler?
What does the equalizer do?
So what are some of your favorite HH questions or topics, based mainly on entertainment value?
Intplm.Hap_Hazzard
  • Intplm.
    Intplm. Member Posts: 3,005
    Or this one. "I know a dead horse when I beat one."
    But seriously, these subjects come up from time to time because different situations that happen tend to bring the subject matter to bare again and again. The context in use just happens to have changed.
    jesmed1
  • LRCCBJ
    LRCCBJ Member Posts: 1,043
    "Should I run one pipe or two pipe (for oil)?
    "Should I install a Tiger Loop"
    jesmed1EBEBRATT-Ed
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    Which brand of radiator vent is best for one-pipe steam?
    What do you call the dry return on a one-pipe system?
    What's the point of using penetrating oil on a sealed pipe joint?
    Which brand of penetrating oil is the best?
    What, if anything, is the best thing to add to your boiler water?
  • DCContrarian
    DCContrarian Member Posts: 1,456
    "Do heat pumps save money?"
    jesmed1LRCCBJ
    EBEBRATT-Ed Member Posts: 20,149
    What is the best boiler?
    What size boiler do I need?
    Should I switch from oil to gas?
    My steam system heats fine but I have no pressure on the gauge.
    How do I remove this rusted pipe fitting? Heat?, Big wrench? Penetrating oil?
    How do I remove rusted tankless heater bolts?
    My boiler will not run and I have no heat and its freezing. No, it worked good since it was installed 15 years ago . It has never been serviced. What's wrong with it?
    delcrossvjesmed1LRCCBJJUGHNE
    hot_rod Member Posts: 27,414
    Is my fuel bill too high?
    jesmed1JUGHNEEBEBRATT-Ed
  • jesmed1
    edited March 2025
    The answer is always "Yes, if you need more BTU's than a hair dryer puts out to heat your house!"
    I realize that right now this includes me and most of the Western world, but hopefully someday we'll have much better insulated housing construction.
    EBEBRATT-Ed
  • jesmed1
    And I forgot to list another recent favorite:
    "Can I use Teflon tape on my oil lines?"
    EBEBRATT-Ed
  • JUGHNE
    JUGHNE Member Posts: 11,547
    Plumber wants to use PVC for my steam pipes……it is a lot cheaper!
    I recall Dan H. telling of visiting a site where that happened.
    jesmed1delcrossv
  • Intplm.
    Do I need purple primer?
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,833
    It especially knocks when in the morning when the thermostat goes up from 55 degrees to 72.
    PC7060delcrossv
    mattmia2 Member Posts: 16,686
    someone should write a book….
  • jumper
    jumper Member Posts: 2,534
    Nobody asked yet about a cheap method to go off grid.
    Hot_water_fan
    " What kind of pipe dope do I use"
    Is my all time favorite.
    It makes me want to scream.
    Intplm.ethicalpaul
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,241
    ”why is installation price x times more than the online price?”
  • jesmed1
    And the related question, "Will it cost less if I help?"
