Your favorite Heating Help questions
The ongoing debate about use of SharkBite fittings made me laugh, because it seems there a number of "hot button" questions that are guaranteed to spark a lively debate here. Here are some of my favorite questions, because they seem to have the highest entertainment value:
1.How large a pickup factor does my steam system really need?
2. What is the actual efficiency of a cast iron boiler?
3. How much money will a new EK 2000 save me?
4. Can I use a SharkBite fitting?
And @EBEBRATT-Ed added some of his favorites:
What type of pipe dope do I use?
How do I add a "C" wire to a thermostat?
My burner will not start, what is wrong with it.
Who makes the best boiler?
What does the equalizer do?
So what are some of your favorite HH questions or topics, based mainly on entertainment value?
Which brand of radiator vent is best for one-pipe steam?
What do you call the dry return on a one-pipe system?
What's the point of using penetrating oil on a sealed pipe joint?
Which brand of penetrating oil is the best?
What, if anything, is the best thing to add to your boiler water?
What is the best boiler?
What size boiler do I need?
Should I switch from oil to gas?
My steam system heats fine but I have no pressure on the gauge.
How do I remove this rusted pipe fitting? Heat?, Big wrench? Penetrating oil?
How do I remove rusted tankless heater bolts?
My boiler will not run and I have no heat and its freezing. No, it worked good since it was installed 15 years ago . It has never been serviced. What's wrong with it?
4 -
Do I need purple primer?
someone should write a book….
”why is installation price x times more than the online price?”
And the related question, "Will it cost less if I help?"
