A Casual Survey: Homeowner GC'ing their job
Mad Dog_2
Mad Dog_2 Member Posts: 8,469
I have reluctantly done this a few times over the years. Rarely goes well. Your thoughts & experiences? Mad Dog
PeteA
    ethicalpaul Member Posts: 8,405
    What kind of job are you thinking of?
  • Intplm.
    Intplm. Member Posts: 2,917
    A home owner GC ??!
    GC—— "But I saw them do it that way on you tube."
    Contractor—— "I did too. Shall I invoke the "difficult GC / home owner clause in the contract.?" Since this is the fifty forth time you have argued this?
    In other words. No F#%^@*G way would I take a job under those circumstances. The headaches and the risks are not worth the hassle.
    Unless of course the relation between customer and contractor is rock solid. But that is a … well… then again. I smell a can of worms.
    PeteAMad Dog_2
  • ratio
    ratio Member Posts: 4,203
    I always figured that if I built a house I'd hire contractors by the day, to give them the option of bailing without feeling too bad about it.
    PeteAMad Dog_2
    hot_rod Member Posts: 27,095
    I've worked with many GCs over the years. The best ones are:
    Knowledgable of the various trades, patient, well organized, have a sense of humor, accommodating, but also firm and assertive.
    Bilingual is a plus, almost a must in my neck of the woods.
    PeteALarry WeingartenMad Dog_2
  • PeteA
    PeteA Member Posts: 310
    I would actually prefer to do my own work under the guidance of the pro.
    The pro works with me to plan out the job. I get the necessary permits I need, procure the materials and build it out. Pro comes by and verifies what I’ve done was done to our plan and helps set up inspections.
    Job gets closed out as complete.
    Homeowner becomes more knowledgeable about trade work and possibly opens up a new revenue stream for the pro without the overheads.
    Mad Dog_2
    Jamie Hall Member Posts: 27,026
    Doesn't this really depend on the scope and complexity of the job? For instance, to actually build a house, let's say, on a vacant lot, there are many trades involved (including some Professional Engineering — or there should be) and the average homeowner would, in my view, be ill advised to be the general contractor. On the other hand, finding a good GC could also be remarkably difficult (to be honest, I can't think oof one in my area for a job of that scope, although there are a couple of firms for commercial work). On the other hand, for building a new deck, same (not all) homeowners would be well qualified. For some other jobs — let's take one I did a couple of years ago, installing a complete minisplit system for an apartment) is the company doing the insallation a GC? There are several trades involved — in this instance, a couple acting as subcontractors to the firm providing and installing the heat pump and commissioning it. Is that firm a GC?
    Fizzy question. fuzzy answer…
    PeteAethicalpaul
    EBEBRATT-Ed Member Posts: 19,914
    No, most of the time Homeowner GC never goes well.
    Half way through the job they want to start adding things.
    There may be some instances where a homeowner may be a excellent GC but most have no clue of the scope of the work installed or what needs to be done.
    Who does clean up
    who disposes of rubbish and rubble
    They want to buy their own material but when the Amazon Junk or HD junk fails they want you to change it out for free.
    If they supply the material they will buy the wrong stuff or it will not be available when you need it.
    PeteAMad Dog_2Intplm.ratio
  • ILikeEmOlder
    ILikeEmOlder Member Posts: 54
    Lots of good comments.
    I’m open to working with homeowners who want to semi-GC the project.
    I bill my rate for “consulting” and send over the invoice (per some kind of payment schedule agreed from the outset).
    I often procure materials & supplies. I often line up subs. I weigh in when they want me to.
    More and more, folks want to take the reins. I used to fight it, not so much anymore.
    Swinging hammers and fitting pipe…bringing the dream to life
    Mad Dog_2
    mattmia2 Member Posts: 16,062
    and how often does it go badly with a professional gc?
    PeteAMad Dog_2
    I think it comes down to the actual person, or people involved, not based on a title or what license they hold necessarily. The interview should be as much about personality as job experience.
    Spell out in writing what is expected from all the parties.
    License and liability can be an issue, bank financing often dictates the legal requirements. My current city allows homeowners to do quite a bit of the GC work if you post a bond, and hve an engineered design, stamped by a state licensed PE.
    I have GCed all my building projects, ground up and remodels. Being in the trades helps you find the subs that will work this way.
    At days end most all the subs helped each others out, when it came their turn to build you reciprocate. At least when we were all starting out in business. And in a small town
    mattmia2delcrossvMad Dog_2PeteA
  • delcrossv
    delcrossv Member Posts: 2,189
    I've GC'd before and things turned out well. I wouldn't have any problem doing it again.
    Mad Dog_2PeteA
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,036
    I am a GC. Still, I've had clients who wanted to keep costs down. If they have the right skills for all the different parts of project management and if I know them pretty well, I'll help them do the job as needed. Some people can't take guidance and only want what they want now, with no ability to look longer term. I won't even refer people for those jobs.
    Yours, Larry
    Mad Dog_2PeteAILikeEmOlder
  • Mad Dog_2
    Paul...kitchens, baths, extensions, dormers...Extended stay jobs...Mad Dog
  • LRCCBJ
    LRCCBJ Member Posts: 1,043
    250K Steam boiler with a drop header and all new NBP………………..extended stay job.😁
    jesmed1
  • Mad Dog_2
    Actual professional experience in one trade is a big plus, but I've had DIYrs & Corporate Office types that were brutal. What I have found is that the HO/GC leans on the "subs" too much because they are not knowledgeable enough & frustrate them. Mad Dog
    ethicalpaulILikeEmOlderdelcrossv
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,810
    Never.
    No residential work.
    Ever.
    ratioMad Dog_2
  • kcopp
    kcopp Member Posts: 4,644
    I would really need to know the customer. A cold call even asking for a remodel of a bathroom is iffy.
    I always ask if a carpenter is involved.
    Most say they are doing the carpentry …. I generally will back away.
    Mad Dog_2
    I had a carpenter buddy that right up front when everything was decided he would say "OK any changes will be a minimum of $500". He said it stopped the changes.
    I used to get it when I was wiring. Go over everything first. Your rough it, the sheet rock goes up . All is well until you finish and the paint is on.
    Then they start,
    "I didn't know the light fixture was going there"
    "I need more outlets over there"
    even though you went over every inch of it with them b4 starting
    They could have looked at the rough
    even after the sr was installed wouldn't be a killer.
    But after the paint is on??
    jesmed1delcrossvMad Dog_2Intplm.
  • PC7060
    PC7060 Member Posts: 1,762
    edited March 2025
    this ^^^^ including a good set of approved drawings with structural and finish details plus materials lists.
