Water movement in sight glass
JBB
JBB Member Posts: 24
What is considered normal amount of water movement in the sight glass? Mine is moving around 2 to 2-1/2 inches during the steam heat cycle. It returns back to mid glass within 4 minutes, once the cycle ends.
    Jamie Hall Member Posts: 27,319
    Are you saying it drops a couple of inches during the cycle, and then as the boiler cools down comes back up? Or does it bounce up and down by two inches or so all during the cycle?
    The former isn't that uncommon — the latter is cause for some concern.
  • JBB
    It drops during the time that the burner is on, then fills back up after that.
    I wouldn't worry about it, so long as it isn't bouncing too much when the boiler is firieng.
    Might have some slow wet returns…
    delcrossv
  • techforlife
    techforlife Member Posts: 127
    Boiler should be skimmed as you have a layer of oily contaminants on the water level.
    delcrossv
  • delcrossv
    delcrossv Member Posts: 2,203
    Possibly slow returns. If it returns to its original level, not much to do about it now.
    If it's so slow it starts tripping the LWCO, the wet returns would need a look see.
  • techforlife
    Easier to skim first than repipe!
  • delcrossv
    True, if skimming would solve the issue. What was reported wasn't surging.
    "It drops during the time that the burner is on, then fills back up after"
  • JBB
    I agree with skimming is probably still being needed. This is a new install that was noisy and inefficient until they skimmed it, which made a world of difference! Thanks for the help!
    Well, skimming wouldn't hurt. Never does. But it won't solve this type of problem — won't even affect it much.
    delcrossvjringel
    ethicalpaul Member Posts: 8,741
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    How long are your heating cycles?
    Does the boiler cycle on pressure before temperature?
    What is your maximum pressure?
