Water movement in sight glass
What is considered normal amount of water movement in the sight glass? Mine is moving around 2 to 2-1/2 inches during the steam heat cycle. It returns back to mid glass within 4 minutes, once the cycle ends.
Are you saying it drops a couple of inches during the cycle, and then as the boiler cools down comes back up? Or does it bounce up and down by two inches or so all during the cycle?
The former isn't that uncommon — the latter is cause for some concern.
It drops during the time that the burner is on, then fills back up after that.
Possibly slow returns. If it returns to its original level, not much to do about it now.
If it's so slow it starts tripping the LWCO, the wet returns would need a look see.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Easier to skim first than repipe!
True, if skimming would solve the issue. What was reported wasn't surging.
"It drops during the time that the burner is on, then fills back up after"
I agree with skimming is probably still being needed. This is a new install that was noisy and inefficient until they skimmed it, which made a world of difference! Thanks for the help!
This could describe minor surging
How long are your heating cycles?
Does the boiler cycle on pressure before temperature?
What is your maximum pressure?
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
