Replumbing: Solder or Threads for Ball Valves
2»
  • Thebestarit
    Thebestarit Member Posts: 1
    edited March 5
    Sweating the joints is solid if you’ve got the skills, but threaded connections make future swaps easier, especially if you ever need to integrate a motor operated valve. Those can be a pain to replace if they're hard-piped in. If the valve’s in a tight spot, threaded might save you a headache later. Just use good pipe dope or tape, and make sure everything’s snug but not over-tightened.
    ethicalpaul Member Posts: 7,694
    Still waiting for evidence that shark bite fittings fail more than sweated or threaded…
    Intplm.
    pecmsg Member Posts: 6,175
    Whats failing that they have to be replaced?
    mattmia2 Member Posts: 13,069
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,870
    Hi, I found one that had failed by a water heater, in a seldom used room. Just a fast drip. Nobody saw it, and it caused roughly $10,000 in damage. It does seem that chlorine and EPDM rubber don't get along very well. So, for me, I'll only use these fittings for temporary repairs.
    Yours, Larry
    mattmia2Mad Dog_2
    Fluoroelastomer is probably the right compound for contact with domestic water although I wouldn't trust even that for the 100+ years I expect a copper plumbing system to last.
    Mad Dog_2
    For ball valves it is usually the ball gets corroded or scaled. For gate valves it is usually the screw that erodes and breaks. Globe valves are probably the most repairable but also most restrictive.
    edited February 27
    That’s a high expectation for copper, even if the installation was good
    Mad Dog_2
  • delcrossv
    delcrossv Member Posts: 2,182
    Nah. I'd call that pretty reasonable- at least with our water.
    mattmia2Mad Dog_2
    Galvanized in cold water is still in usable shape after 60 or 70 years, 100 years out of soldered copper is reasonable. I'm not convinced about the o-rings in propress either although it is crimped in such a way that there is a lot less reliance on it remaining pliable.
    delcrossvMad Dog_2
  • delcrossv
    edited February 27
    We're up to 113 years with galvanized on one of the buildings. Some pressure loss, but still working. I'd say soldered copper has an indefinite lifespan. (>100 years)
    Mad Dog_2
  • ChrisJ
    ChrisJ Member Posts: 16,766
    That depends on a lot.
    I had a galvanized water line that I doubt was over 70 and it was almost completely plugged from minerals AND rusted thin enough in a few spots it was sweating in the mud. I say sweating because it was leaking, but so little it was only wet, kind of like it was a long soaker hose. Next to it in the basement was a previous length of galvanized pipe that wasn't great either, no idea how old that was.
    Also, I had some copper plumbing that was 70+- that was fine, but I'm glad I replaced it. That was clean on the inside, no mineral build up.
    We've also seen how the water in some areas can eat through copper pipe and in those areas pex will have a better life. Like copper, minerals don't build up in pex.
    Seems like most plumbing should be expected to last 50 years. Anything over that is a bonus not to mention any of this plumbing will also have valves of some sort and those will have rubber in them. Expecting a "plumbing system" to last 100 years is unreasonable. Yes, some have but most have not weather it's mineral build up, failed joints, failed valves, rusted/rotted piping or modifications to the building.
  • delcrossv
    edited February 27
    @ChrisJ Definitely water dependent. There are a lot (like thousands) of buildings here with 100 year old water pipes. But Lake Michigan water is easy on pipes compared to elsewhere .
  • ChrisJ
    Perhaps.
    But on a worldwide scale that's pretty tiny.
    trivetman
  • delcrossv
    edited February 27
    Maybe, maybe not, if we're talking water quality. Yeah ,Chicago may be exceptional, but it's not the only place where copper would have a century+ lifespan.
    Mad Dog_2
    edited February 27
    better quality gate valves just need the packing replaced every several decades.
    galvanized pipe in the ground will rust from the outside in in most soils. Usually it develops pinholes that produce a fine mist when it fails. the stuff that I cut out of my mom's house a couple years ago on the cold water was from the late 50's and seemed mostly clear although it did have one pinhole that had a rust spot on it. It had been on detroit water for a long time although I know the city had its own wells and water tower at some point, I don't know when that was replaced with a connection to the Detroit system, if it was before or after the house was built.
  • Larry Weingarten
    Hi, @ethicalpaul , Actually, the failure I found was a Shark Bite, and it seems they use EDPM rubber. I looked up Viega propress fittings, and it seems they use EPDM as well. 🤨
    Yours, Larry
    Mad Dog_2
    edited February 28
    Thanks Larry! Now I wonder if that sharkbite was installed correctly. Because we know that any fitting installed incorrectly is more likely to fail. This is the problem with anecdotal stories of "I saw one fail once" or even "I've seen a dozen fail"
    Absolutely, but did none of those fittings ever fail in that time? I kind of think a lot of plumbers would be out of business if copper never failed. We're not really talking about how long something can possibly last, we're (or at least I am) talking about the failure rate of various fitting technologies, and I'm saying there's no real data out there that I have seen.
    Mad Dog_2
  • Larry Weingarten
    Hi @ethicalpaul , I agree. With sweat copper, there must be a lot of qualifiers. Was it properly prepped? Was the joint made well and not overheated? Is it properly supported if needed? Is it sized correctly for the flow? Water hammer? What is the water pressure? Water quality? Stray current? … Only if all of those things line up can you say you expect to get 100 years from the system. All that said, I do think rubber is a relatively weak system component compared to copper, so I'd be careful where I put it. I don't want to have to wait decades for the numbers to come in, so rely on the properties of materials to attempt to make educated guesses. … About that Shark Bite, I'm thinking it was installed so there was a little tension pulling to the side. Maybe it had something to do with the failure. If so, the design is too delicate to be used widely. We'll see if push-fittings go the way of polybutylene plumbing. 🙀
    Yours, Larry
    ethicalpaulMad Dog_2
  • delcrossv
    edited February 28
    "Absolutely, but did none of those fittings ever fail in that time? I kind of think a lot of plumbers would be out of business if copper never failed"
    You're saying 2 different things. Pipes can be fine, while fittings (valves, taps, etc) may need more frequent replacement/service.
    No worries, plumbers have plenty to do, just not a lot of it is replacing pipes.
    Mad Dog_2
    edited February 28
    I thought we were talking about fittings, and of course, their connection to the pipes
  • ChrisJ
    edited February 28
    I thought we were talking about the entire system.
    I mean, the thread is about replacing valves………
    delcrossv
    Valves are fixtures I think? The thread was about the difficulty of replacing valves with the various connection technologies available. We are really getting meta now!
  • ChrisJ
  • Larry Weingarten
    Okay, Back to the original question of sweat vs threaded connections for valves. My approach has long been to use threaded valves, as valves eventually fail. If I can build things so a torch is not needed the next time around, that's a plus in my mind. 😇
    Yours, Larry
    mattmia2delcrossv
  • JUGHNE
    JUGHNE Member Posts: 11,444
    edited February 28
    So then 2 male adaptors and a sweat union……..could be more than the ball valve itself. But I understand looking to the future.
    But there are brass compression X male thread. I use them on pressure relief valve drop pipes to avoid the torch for replacement/removal of the PRV.
    PC7060Larry Weingarten
    I used a 5/8 / 1/2 flare to 1/2 ips for that reason last time i ran in to this situation. maybe i posted a picture above 2 years ago when tis thread was new
    delcrossv
