Replumbing: Solder or Threads for Ball Valves
Still waiting for evidence that shark bite fittings fail more than sweated or threaded…
See my sight glass boiler videos: https://bit.ly/3sZW1el1 -
Whats failing that they have to be replaced?
For ball valves it is usually the ball gets corroded or scaled. For gate valves it is usually the screw that erodes and breaks. Globe valves are probably the most repairable but also most restrictive.
well not if they were already failing
what are the o-rings in pro press made out of?
That’s a high expectation for copper, even if the installation was good
That depends on a lot.
I had a galvanized water line that I doubt was over 70 and it was almost completely plugged from minerals AND rusted thin enough in a few spots it was sweating in the mud. I say sweating because it was leaking, but so little it was only wet, kind of like it was a long soaker hose. Next to it in the basement was a previous length of galvanized pipe that wasn't great either, no idea how old that was.
Also, I had some copper plumbing that was 70+- that was fine, but I'm glad I replaced it. That was clean on the inside, no mineral build up.
We've also seen how the water in some areas can eat through copper pipe and in those areas pex will have a better life. Like copper, minerals don't build up in pex.
Seems like most plumbing should be expected to last 50 years. Anything over that is a bonus not to mention any of this plumbing will also have valves of some sort and those will have rubber in them. Expecting a "plumbing system" to last 100 years is unreasonable. Yes, some have but most have not weather it's mineral build up, failed joints, failed valves, rusted/rotted piping or modifications to the building.
@ChrisJ Definitely water dependent. There are a lot (like thousands) of buildings here with 100 year old water pipes. But Lake Michigan water is easy on pipes compared to elsewhere .
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
better quality gate valves just need the packing replaced every several decades.
galvanized pipe in the ground will rust from the outside in in most soils. Usually it develops pinholes that produce a fine mist when it fails. the stuff that I cut out of my mom's house a couple years ago on the cold water was from the late 50's and seemed mostly clear although it did have one pinhole that had a rust spot on it. It had been on detroit water for a long time although I know the city had its own wells and water tower at some point, I don't know when that was replaced with a connection to the Detroit system, if it was before or after the house was built.
Hi, @ethicalpaul , Actually, the failure I found was a Shark Bite, and it seems they use EDPM rubber. I looked up Viega propress fittings, and it seems they use EPDM as well. 🤨
Yours, Larry
1 -
Thanks Larry! Now I wonder if that sharkbite was installed correctly. Because we know that any fitting installed incorrectly is more likely to fail. This is the problem with anecdotal stories of "I saw one fail once" or even "I've seen a dozen fail"
Absolutely, but did none of those fittings ever fail in that time? I kind of think a lot of plumbers would be out of business if copper never failed. We're not really talking about how long something can possibly last, we're (or at least I am) talking about the failure rate of various fitting technologies, and I'm saying there's no real data out there that I have seen.
Hi @ethicalpaul , I agree. With sweat copper, there must be a lot of qualifiers. Was it properly prepped? Was the joint made well and not overheated? Is it properly supported if needed? Is it sized correctly for the flow? Water hammer? What is the water pressure? Water quality? Stray current? … Only if all of those things line up can you say you expect to get 100 years from the system. All that said, I do think rubber is a relatively weak system component compared to copper, so I'd be careful where I put it. I don't want to have to wait decades for the numbers to come in, so rely on the properties of materials to attempt to make educated guesses. … About that Shark Bite, I'm thinking it was installed so there was a little tension pulling to the side. Maybe it had something to do with the failure. If so, the design is too delicate to be used widely. We'll see if push-fittings go the way of polybutylene plumbing. 🙀
Yours, Larry
2 -
"Absolutely, but did none of those fittings ever fail in that time? I kind of think a lot of plumbers would be out of business if copper never failed"
You're saying 2 different things. Pipes can be fine, while fittings (valves, taps, etc) may need more frequent replacement/service.
No worries, plumbers have plenty to do, just not a lot of it is replacing pipes.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1 -
I thought we were talking about fittings, and of course, their connection to the pipes
Valves are fixtures I think? The thread was about the difficulty of replacing valves with the various connection technologies available. We are really getting meta now!
pex makes replacing valves really really easy.
