Help! Storm and no heat
Desdemona
Desdemona Member Posts: 5
Our wood furnace is indicating that it is overheating, yet there is hardly any wood left in the box. Our heating system relies on a combination of wood and oil through a boiler located in the basement, but we currently have no oil available. We are solely using wood for heating, and all the radiators are cold. We observed last night that the radiators were not warming up, so today we flushed each one. Additionally, we heard a high-pitched buzzing noise coming from the pump connected to both the boiler and the wood stove, which is a Grundfos model. We attempted to reset the power, but there was no change. We hear it turn on but then it switches off after a few minutes. This grundfos pump lacks a valve or bleed feature. We reset the temperature to the maximum of 160 degrees, yet it continues to overheat. What steps should we take next?
9cb6e3e7-d4f4-49ce-9fc4-314191dd6c40.jpg 49019fa4-bf26-44eb-835f-72a3f5d4c199.jpg 1b97ca5f-eb20-4b2b-9693-4ce11995c971.jpg
  • delcrossv
    delcrossv Member Posts: 2,184
    edited February 18
    Any water in the boiler? Valves all open?
    hot_rod Member Posts: 25,344
    what was the indication that it overheated?
    Did it steam or cause a relief valve to discharge?
  • Desdemona
    Yes water is in the boiler.
    Yes valves are open. (nothing has been turned since we moved in a year ago)
    The thermostat on the woodstove shows 210f. There is barely any wood in it. A few months back, I did put too much wood in and steam was released and the temp showed 190f. This time, no steam, barely had any wood in it.
  • jesmed1
    jesmed1 Member Posts: 1,260
    edited February 18
    "Additionally, we heard a high-pitched buzzing noise coming from the pump connected to both the boiler and the wood stove, which is a Grundfos model. We attempted to reset the power, but there was no change. We hear it turn on but then it switches off after a few minutes."
    Buzzing noise = pump locked up?
  • delcrossv
  • Desdemona
    Yes, a very high-pitch buzzing noise.
    Earlier today there was a loud buzzing noise that was coming from the Grundfos unit. We bled each radiator throughout the house, opened the wood stove box, ceased adding wood, and reset the power to the Grundfos. Everything resumed functioning after about ten minutes, but then a very high-pitched noise came from the Grundfos, and all operations halted once more.
    pecmsg Member Posts: 6,290
    better picture of the pressure gauge?
    Jamie Hall Member Posts: 26,182
    If the pressure is OK — air bound, or the pump has died.
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,897
    Hi, The blue pump has a plug on the back of the motor that can be unscrewed, and then you can feel whether the rotor is turning by gently poking a phillips screwdriver or some-such into the opening that's uncovered. I've used this approach to move and free up stuck rotors too. I don't know if the red pump has similar access. 🤔
    Yours, Larry
  • Desdemona
    The fire is completely out. Temp has gone down finally. Temp shows 90.
    e3cb933f-7fd2-4739-93d2-007497e6cd3b.jpg b9a93208-d116-4bb7-ac66-da391a8263fc.jpg
    90*C is near 200*
    with the fire out how is that possible?
    Your boiler pressure is too low. Or much too low, depending on which gauge I believe. I'd want to see it around 15 psig — 33 feet. The pump may be airbound, or the system may need to be purged.
    delcrossv
  • delcrossv
  • Desdemona
    Yes - only 2 or 3 embers. The fire went out 8 hours ago. The temp has dropped considerconsiderably from the first picture we took of the gauge. (Look at first picture)
    Jamie Hall
    is there a way to release the air via a valve? The pump does not seem to have a valve/screw release. The pump is emitting a high pitch buzz.
    mattmia2 Member Posts: 13,498
    if you slowly add water does the pressure go up? gravity should allow water to flow in to the circulators, the air will be at the high points.
