rinnai 38k vented heater “L” on display
garye5007
garye5007 Member Posts: 3
Picked up a Rinnai 38K vented heater,used,.hooked it up to gas to test it fires up ok.i set the temperature at 78° and it shows L on display. The manual states that it’s in low combustion mode (I think). It’s in a cold room. No error code. Can I get this thing to run in high combustion mode?
    Jamie Hall Member Posts: 27,013
    Got the manual?
  • garye5007
    yes, I have the manual . Says this.
  • garye5007
    also this… temp control logic?
  • yellowdog
    yellowdog Member Posts: 287
    Does it show it after the setpoint temp goes away? How cold is the room you have it in?
