New Indirect Water Tank
Hello. I am looking to replace my existing indirect water tank and am looking for some guidance/advice. I currently have a 40 gal Heat-flo indirect tank that is 13 years old. We just completed a bathroom remodel and noticed the shower doesn't maintain hot water very long. Can somebody recommend a good indirect unit? My house is an 1100 sq ft ranch - it is just my wife and I.
Thank you!
My advice is retire the indirect and try a heat pump water heater.
run it until it leaks, why not.
Are you using a high flow shower head or body sprays? 40 gallons doesn't go far at 5- 15 or more gpm.
What temperature is the tank set to? You might crank it up 10° to extend the drawdown.
A good chance the coils are coated with line scale, dropping performance.
How much and how often you use dhw would help decide if a hpwh will be a good fit. If you use a lot of dhw throughout the day a hpwh may not be good for you. And the location of the tank, size of the room is important.
What size is the boiler? I like the way EK generates DHW with an external plate HX and a basic storage tank. Very high efficiency and the thermal purge adds to the benefits. If you want a large dump load of dhw get a plate HX and an 80 gallon electric tank.
Now you have a dual fuel system with large dump, high recovery. Possibly less $$ than a new indirect.
Living the hydronic dream1 -
Does this model use a dip tube? If so it may have broken apart.
do you have the manual for the tank? Some models are top feed, some are bottom. Their website has the info, probably for legacy models also.
What are some options for a heater-element-less storage tank as a replacement for an EK? Mine is about 11 years old and I've been wondering what to buy when the time comes. Seems like their tank is just an electric tank without heaters.
about the least expensive insulated glass tank you can buy is an electric water heater, they manufacturer millions every year. You may find a buffer tank is more $$
Price them out online.
The buffer specific tanks will have larger ports generally
Hi, Another benefit to using an electric tank-type heater is you can wire it in for backup heating, should that ever be needed.
Yours, Larry
I was thinking that as well
what is the temperature setting?
What’s the outlet temperature?
Rais the storage temperature to 150 or 160 and reduce it down to 110 - 130*
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
