New Return Pipe Noise During Renovation
13»
  • JodiMe
    JodiMe Member Posts: 117
    @EzzyT i think I found your contact info - Woodland Park, right? Would you come to Cranford?
    @clammy, where are you located and is Cranford within your service area?
    i definitely need an expert in steam right now….
  • EzzyT
    EzzyT Member Posts: 1,377
    @JodiMe I service the cranford area. The best way to reach is at 2018878856
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    JodiMeCLambdelcrossv
  • JodiMe
    awesome. I’ll give you a call. Is it ok if I call over the weekend or wait until Monday?
  • EzzyT
    You can call over the weekend
    201-887-8856
    JodiMedelcrossv
  • JodiMe
    Wanted to say thanks to everyone on this thread for the help troubleshooting all along the way.
    And especially @ezzy who came in and fixed our system in a day. We haven’t heard a thing since it was done. Amazing. A true pro. Very grateful for this wall!
    109A_5delcrossvbburd
  • danmayer175
    danmayer175 Member Posts: 60
    @JodiMe
    There is a section in Lost Art of Steam Heating that describes this exact scenario of how a new boiler can turn an old wet return into a slamming dry return. And how to fix it with a false waterline. Highly recommend the book. Best $50 I've spent owning a steam system. My HVAC tech has gotten a copy for himself.
    Homeowner in Middletown, PA
    1936 house with 1996 Burnham V74 oil-fired 1-pipe system
    JodiMe
    109A_5 Member Posts: 3,428
    As much as a false waterline would have cured the noise and it was previously mentioned in this thread, at the future time of a boiler replacement, the installer (if not a steam expert) may screw it up (who needs all these extra pipes). In this case, I think having the wet return lowered is a better solution, since it could be done, and it is a more permanent repair. It may have taken a bit longer to do with working with and around some obstacles.
    https://heatinghelp.com/store/detail/we-got-steam-heat-a-homeowners-guide-to-peaceful-coexistence/
    And others
    https://heatinghelp.com/store/category/steam-heating-books/
    JodiMe
