Burnham v13a running constantly
Happy New Year! Thanks for your attention!!
I bought this place 3 years ago and the dhw has always been scalding hot. I have a feeling the previous home owner removed the mixing valve for dhw (photo of where I think it used to be) for cheap fix and the sensor or thermostat is set for the highest temp. I had it serviced last year and they couldn't figure out how to turn it down.
I am rarely home and hardly ever use the hot water. Is there a way to disable/disconnect the sensor or thermostat for the dhw so its not always trying to make 200 degree domestic hot water??
Thanks!!
slip off the grey cover all the way to the right in the last picture and post a shot of the settings inside,
known to beat dead horses0 -
cut your domestic hot water off of that crusty beast and get a standalone water heater
neil : I have tried everything with the settings on the 3 little dials in the box… turned them as low as they go but doesnt do anything. This boiler is supposed to have a knob on a mixing valve to adjust the temp but its not there.
Paul: yes exactly! how do I turn it off??????
my right hand and my left hand got confused, and now i see 2 grey aquastats,
show what's inside the domestic, the one on it's own plate with the copper pipes, and of the other,
then call a plumber to pipe in a mix valve on your domestic,
or,
@ethicalpaul wants you to cut the domestic copper going to the boiler, and buy a heatpump water heater instead,
known to beat dead horses1 -
could it be as simple as disconnecting the thermostat wire for the domestic hot water? Then it would stop trying to heat it? Any idea which one it is?
Begin the process of getting it replaced.
Get an accurate Manual "J" Heat Load / Loss done to determine the size boiler needed.
Make up a list of items that will need replacing, there a lot of crusty pipes in that picture.
Get several quotes from contractors with references. Check on the references!
You could even get the replacement in place and ready to go once the weather or that boiler breaks!
2 -
I appreciate everyone's input!🙏 Most of the crusty damage happened years ago and I've been told its tight for now.. maybe like the Millennium Falcon? hahaha
I agree it needs replacing soon
Please direct me on how to turn off the demand for Domestic Hot Water.. so it thinks it's just a regular heating boiler?
Nobody knows how to bypass the dhw demand?
Unfortunately since the hot water coil is integrated into the tank of the boiler it can’t just be “bypassed”. The water for the domestic side (faucets, showers) picks up it’s heat from whatever the internal tank temperature is set at inside the boiler , which as you’ve indicated can be incredibly hot due to the lack of a tempering valve/mixing valve.
Your boiler may be in lousy shape but a local plumber should be able to install a mixing valve to make it safe to use your hot water while you scout out a contractor for a full boiler replacement. Avoid scalding yourself or someone else at all costs.
- 116 Geothermal
