Mini Split
RRyan83
RRyan83 Member Posts: 4
Does Mitsubishi offer any line set extensions for their minisplits?
thanks
    HVACNUT Member Posts: 7,308
    Its probably set up to have a contractor contact you if you're not the contractor.
    pecmsg Member Posts: 6,894
    who’s sizing this
    Who’s purchasing this
    Who’s installing this
  • RRyan83
    I sized it for the 9,000 btu system. I will purchase and install it
  • ratio
    ratio Member Posts: 4,203
    Download the manual from mylinkdrive.com & see what the limits are. If it's the same as the one I vaguely remember, the limit is over 150'. After 70' you need to add charge, after 150' you need to add oil.
    edited January 2025
    Mitsubishi does not honor online purchases for warranty.
    F. PROPER INSTALLATION. This Limited Warranty applies only to Systems that are installed by contractors who are licensed for HVAC installation under applicable local and state law, and who install the Systems in accordance with (i) all applicable building codes and permits: (ii) METUS’s installation and operation instructions: and (iii) good trade practices.
    9000 being the smallest they make. What is the actual heat load / loss for this room?
  • yellowdog
    yellowdog Member Posts: 287
    @RRyan83 What exactly are you trying to do?
  • GW
    GW Member Posts: 5,152
    "line set extensions", I don't know what this means
    we buy 164 foot line sets and cut them to each job. Gotta be on the ball if you're installing yourself. Good luck
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    Line Set Stretchers…………..
    Available on Amazon.
