Mini Split
Does Mitsubishi offer any line set extensions for their minisplits?
thanks
Its probably set up to have a contractor contact you if you're not the contractor.
who’s sizing this
Who’s purchasing this
Who’s installing this
I sized it for the 9,000 btu system. I will purchase and install it
Download the manual from mylinkdrive.com & see what the limits are. If it's the same as the one I vaguely remember, the limit is over 150'. After 70' you need to add charge, after 150' you need to add oil.
Mitsubishi does not honor online purchases for warranty.
F. PROPER INSTALLATION. This Limited Warranty applies only to Systems that are installed by contractors who are licensed for HVAC installation under applicable local and state law, and who install the Systems in accordance with (i) all applicable building codes and permits: (ii) METUS’s installation and operation instructions: and (iii) good trade practices.
9000 being the smallest they make. What is the actual heat load / loss for this room?
"line set extensions", I don't know what this means
we buy 164 foot line sets and cut them to each job. Gotta be on the ball if you're installing yourself. Good luck
Line Set Stretchers…………..
Available on Amazon.
