Foreign fitting (to me)
GM_73
GM_73 Member Posts: 11
Hello all,
Attached is a photo of a fitting on a 2 pipe steam radiator. Most of the radiators in the house have the familiar (to me) return circular traps. Others have this "foreigner". Any help greatly appreciated.
Thank you
  • TKPK
    TKPK Member Posts: 74
    vapor system ball trap. Picture and description in lost art. See if I can find the picture.
    Jamie Hall Member Posts: 27,221
    They work splendidly and are simple.
    Provided you keep your pressure down. Not more than 8 OUNCES (half a pound) per square inch shutoff. You'll need a vapourstat to make this system run right.
    Mad Dog_2Ironmanmattmia2
    Steamhead Member Posts: 18,393
    This is an O-E Vapor system but someone replaced these original return fittings with standard traps.
    Consulting
