Foreign fitting (to me)
GM_73
Member Posts: 11
Hello all,
Attached is a photo of a fitting on a 2 pipe steam radiator. Most of the radiators in the house have the familiar (to me) return circular traps. Others have this "foreigner". Any help greatly appreciated.
Thank you
vapor system ball trap. Picture and description in lost art. See if I can find the picture.
They work splendidly and are simple.
Provided you keep your pressure down. Not more than 8 OUNCES (half a pound) per square inch shutoff. You'll need a vapourstat to make this system run right.
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
This is an O-E Vapor system but someone replaced these original return fittings with standard traps.
Consulting0
- 123 Chimneys & Flues
