What size are the bolts securing the coil plate to Burnham V-74-T
Hi group, I am about to replace the coil on my boiler and need to order new rods and nuts in stainless steel to make it easier next time I want to service it.
Does anyone know the thread size I need?
Thank you in advance!
Good to know, thank you. Do you know the size?
If you can measure across the flats on the head accurately…………I can give you the size. What I cannot give you is the length. That depends on the tapped holes in the casting. We'd need to make an assumption.
Thank you LRCCBJ. It is 1/2". I am getting rods so don't really need the length.
If you really want to make it easier next time, be sure to use anti-seize on the threads. Otherwise you will be doing this. Scroll down to the photo of the OP cutting the bolt heads off with an angle grinder.
Not sure which Burnham boiler you have but on my old 4B series, those bolts are described in the parts list as:
'3/8" - 16 x 3/4" LG Machine Screw'. They take a 9/16" wrench.
(And I had thought mine were stainless steel—I have to tighten them from time to time. But in looking at them now, I am not sure.)
I'm 99% certain that they are 3/8. I'd get 1.25" studs for it.
If you are exactly 1/2…….or slightly less…………they are 5/16" screws.
If you are 9/16………….they are 3/8" screws.
Be careful and use the one that is least corroded.
Wow, this is great! Thank you everyone for all your help and suggestions!
I'll provide an update once finished.
- 50 Industry Classes
