What size are the bolts securing the coil plate to Burnham V-74-T
nelaco
nelaco Member Posts: 21
Hi group, I am about to replace the coil on my boiler and need to order new rods and nuts in stainless steel to make it easier next time I want to service it.
Does anyone know the thread size I need?
Thank you in advance!
    pecmsg Member Posts: 7,166
    edited December 2024
    Please don't use stainless steel bolts. Too brittle will break easy. Steel bolts with never-seize.
    LRCCBJ
  • nelaco
    Good to know, thank you. Do you know the size?
    Not off hand. When you order the coil order the bolts as well.
    nelaco
  • LRCCBJ
    LRCCBJ Member Posts: 1,043
    If you can measure across the flats on the head accurately…………I can give you the size. What I cannot give you is the length. That depends on the tapped holes in the casting. We'd need to make an assumption.
  • nelaco
    Thank you LRCCBJ. It is 1/2". I am getting rods so don't really need the length.
  • jesmed1
    jesmed1 Member Posts: 1,487
    If you really want to make it easier next time, be sure to use anti-seize on the threads. Otherwise you will be doing this. Scroll down to the photo of the OP cutting the bolt heads off with an angle grinder.
  • Chris_L
    Chris_L Member Posts: 354
    Not sure which Burnham boiler you have but on my old 4B series, those bolts are described in the parts list as:
    '3/8" - 16 x 3/4" LG Machine Screw'. They take a 9/16" wrench.
    (And I had thought mine were stainless steel—I have to tighten them from time to time. But in looking at them now, I am not sure.)
  • LRCCBJ
    I'm 99% certain that they are 3/8. I'd get 1.25" studs for it.
  • LRCCBJ
    If you are exactly 1/2…….or slightly less…………they are 5/16" screws.
    If you are 9/16………….they are 3/8" screws.
    Be careful and use the one that is least corroded.
    EdTheHeaterMan Member Posts: 12,424
    jesmed1LRCCBJ
  • pedmec
    pedmec Member Posts: 1,443
    Burnham parts list has them at 3/8"-16 x 7/8"
    LRCCBJ
    EBEBRATT-Ed Member Posts: 20,347
    The idea of using rods or studs is a good idea…….with never seize of course. It gives you two chances to get the nut or the stud out instead of one
    LRCCBJ
  • nelaco
    Wow, this is great! Thank you everyone for all your help and suggestions!
    I'll provide an update once finished.
