Will I break this?
Want to try my hand at replacing this Warren Webster steam trap element but the cap is not budging. I’ve tried a 12” adjustable wrench but have not tried escalating to a cheater bar or impact wrench.
Should I back away slowly and call a pro or keep at it? Thanks!
HEAT! and a bigger wrench. I'd use a big socket and a breaker bar. But first I'd heat it up with a torch and give it some taps with a hammer, not too hard but hard enough. Maybe some penetrating oil for good measure.
2 -
It depends - can you afford to have your system broken for a couple of days while you wait for a mechanic at regular (vs. emergency) rates?
If you can, then I'd say go for it.
When I tried to break some of these old fittings, I'd wait until summer when the system was off and I could wait for the mechanic rather than break my system the winter and freeze my house.
I've managed to replace or repair 14 steam traps out of season this way.
On the other hand, when I do have an idea of something to do in the middle of the season, like add a vent to a slow radiator, I give it a try as you did. When I can't do it, rather than push to the point of breakage I call the mechanic.
2 -
It's amazing what a little heat — not much — maybe a little penetrating oil… and an impact wrench will do.
The "penetrating oil" approach is a fallacy. It never gets inside the threads unless:
- Gravity is driving it there
- You wait for 36 hours, minimum to allow gravity to do the work.
You are correct regarding the heat. Nothing beats it. And, sometimes you need quite a bit of it. 225F or more to reduce the required torque significantly.
2 -
Put a backup wrench on the trap so you don't break the small pipe connections. Use a cheater on the back up wrench and a cheater on the socket or wrench on the cap. Socket is the best if you have one.
Hold the back up and hit the wrench that is on the cap with a hammer. You need three hands to do this sometimes. Penetrating oil will probably do nothing.
An impact with a socket is the best as vibration is your friend.
It will come off
I have rebuilt 100s of traps and very few if any would not come apart.
Worse comes to worse replace the trap and the radiator spud.
5 -
if there is a space for penetrating oil to get in to capillary action will pull it there buy usually stuff that is stuck has the threads pretty solidly filled in
Thanks for the advice, all!
Cordless, brushless Milwaukee impact wrench. Quick and easy
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
I've changed dozens of the 512 in my time. Use a backup wrench at the bottom, and a socket with bar on the top. Tap around the top edge as you increase forces. Never broke anything.
Oil and steam are not good partners. Use penetrating oil as a last measure, and clean up well before reinstalling the cap and new bellows.
Quite a bit of heat makes it liquid.
226 degrees f is not hot.
propane torch hot it what you need.0
- 117 Geothermal
