Will I break this?
Want to try my hand at replacing this Warren Webster steam trap element but the cap is not budging. I’ve tried a 12” adjustable wrench but have not tried escalating to a cheater bar or impact wrench.
Should I back away slowly and call a pro or keep at it? Thanks!
  • Grallert
    Grallert Posts: 1,184
    HEAT! and a bigger wrench. I'd use a big socket and a breaker bar. But first I'd heat it up with a torch and give it some taps with a hammer, not too hard but hard enough. Maybe some penetrating oil for good measure.
    tomoldLRCCBJ
  • KarlW
    KarlW Posts: 184
    It depends - can you afford to have your system broken for a couple of days while you wait for a mechanic at regular (vs. emergency) rates?
    If you can, then I'd say go for it.
    When I tried to break some of these old fittings, I'd wait until summer when the system was off and I could wait for the mechanic rather than break my system the winter and freeze my house.
    I've managed to replace or repair 14 steam traps out of season this way.
    On the other hand, when I do have an idea of something to do in the middle of the season, like add a vent to a slow radiator, I give it a try as you did. When I can't do it, rather than push to the point of breakage I call the mechanic.
    bburdtomold
    mattmia2 Posts: 17,994
    If the system is functioning properly you should be able to just close the valve if the trap were to break. You can also remove it and cap the pipes or replace the whole trap. There should not be steam in the returns unless traps are bad somewhere.
    tomoldethicalpaulfixitguy
  • It's brass. It will come apart. As Grallert says, heat it. Hammer it. An impact wrench should do well too.
    TKPKLRCCBJtomoldGrallert
    Jamie Hall Posts: 27,737
    It's amazing what a little heat — not much — maybe a little penetrating oil… and an impact wrench will do.
    But. Have a backup wrench on the body of the thing!
    tomoldGrallert
  • LRCCBJ
    LRCCBJ Posts: 1,043
    The "penetrating oil" approach is a fallacy. It never gets inside the threads unless:
    1. Gravity is driving it there
    2. You wait for 36 hours, minimum to allow gravity to do the work.
    You are correct regarding the heat. Nothing beats it. And, sometimes you need quite a bit of it. 225F or more to reduce the required torque significantly.
    tomoldethicalpaul
  • Intplm.
    Intplm. Posts: 3,140
    Good advice is offered above. But I would have a full replacement on hand just in case the whole thing gets damaged.
    tomold
    if there is a space for penetrating oil to get in to capillary action will pull it there buy usually stuff that is stuck has the threads pretty solidly filled in
  • Thanks for the advice, all!
  • I see the use of impact guns be included I didn't see heat/freeze cycling mentioned. Here is a link discussing Oil of Wintergreen. https://www.doublegunshop.com/forums/ubbthreads.php?ubb=showflat&Number=271527&page=all
    guzzinerd
  • guzzinerd
    guzzinerd Posts: 463
    Cordless, brushless Milwaukee impact wrench. Quick and easy
    Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
  • retiredguy
    retiredguy Posts: 1,103
    When I rebuilt these traps, I used an 18" Crescent wrench (USA made} and a 6 point socket wrench with a cheater pipe. Pull both wrenches at the same time with equal pressure on each wrench. Worked every time.
    delcrossv
  • I've changed dozens of the 512 in my time. Use a backup wrench at the bottom, and a socket with bar on the top. Tap around the top edge as you increase forces. Never broke anything.
    Oil and steam are not good partners. Use penetrating oil as a last measure, and clean up well before reinstalling the cap and new bellows.
    Intplm.
  • You are correct regarding the heat. Nothing beats it. And, sometimes you need quite a bit of it. 225F or more to reduce the required torque significantly.
    Quite a bit of heat makes it liquid.
    226 degrees f is not hot.
    propane torch hot it what you need.
