Hot Water Heat Question
Mark N
Mark N Member Posts: 1,148
Can you run a hot water heat system with the water turned off at the main for a week or 2 if you're away?
Thanks
    pecmsg Member Posts: 7,039
    as long as it doesn’t leak!
    i wouldnt
  • Mark N
    Thanks that's what I was thinking
  • GroundUp
    GroundUp Member Posts: 2,513
    A closed loop system should never need water once it's established, so unless you have a terrible leak (which is a much larger issue), there is no harm in running the system with domestic water turned off. I have hundreds of systems installed out there with no connection to the domestic water at all.
    hot_rod Member Posts: 27,413
    Needs to have a backflow device, turn off the supply to the boiler
    Jamie Hall Member Posts: 27,319
    Yes — assuming that there is a low water cutoff on the boiler.
    MikeAmann
    EBEBRATT-Ed Member Posts: 20,145
    Most glycol systems are just a water an antifreeze system. All the ones I installed had no city water connected for make up and no glycol make up system. And I am talking systems with 6" pipe and larger.
    We had emergency valve so you could fill the system with water and dilute the glycol only by intentionally attaching a hose in two places.
