Question: Soldering vs. ProPress Coupling for Dirt Magnet and Air Eliminator
Hi everyone,
I'm in the final stages of my project and could use some advice. I bought a dirt magnet and an air eliminator that have the same type of connection, and I'm trying to figure out whether I should use a copper coupling and solder (weld) it in, or if I should go with a ProPress coupling instead.
The challenge is that the dirt magnet has some plastic components inside, so I'm worried that using heat for soldering might cause the plastic to melt. I also have welding couplings and elbows on hand, but I'm not sure if that's the best choice in this case.
What would you recommend? Should I risk soldering, or is using ProPress the safer and better option here?
Thanks for the help!
Soldering & welding are not interchangeable. Those are solder joints. Mad Dog
5 -
Those are sweat sockets: you have to solder them.
I’d use low temp silver bearing solder. There’s no need to disassemble it if you know how to properly sweat pipe. If not, I’d return it and get one that’s threaded or one with press fittings.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.4 -
Thanks @mattmia2 @pecmsg @Mad Dog_2 @Ironman @delcrossv @hot_rod for you comments of help, I really appreciate.
I understand that I need to solder these parts. I'll use low heat and keep the flame at a greater distance to avoid overheating. I'll also make sure to keep the flame as far away from the body as possible. Additionally, I’ll use cooling gel to cool down the body part immediately after soldering. I plan to do this for both the dirt magnet and the air eliminator.
Thanks so much guys, I am in my last step to finish the system. It would be very hard without all you! I appreciate a lot
The gel is to stop heat migration while soldering. you can do the same thing with placement of a wet rag. In the case of that housing i don't think there is a lot either would do without making it difficult to heat the joint. To cool it after just wrap a wet rag around it or spray it with water if you want to cool it faster.
2 -
Nice, cold wet rag wrapped around the body. Don't cook it...When the solder flows, that's hot enough. Keep your flame moving to heat all equally. Mad Dog
1
